Help needed to identify 1.1 Balun
- Buick Mackane
- Has thanked: 111 times
- Been thanked: 65 times
I know its 1.1 but is it a voltage Balun or Current ? Going by photos I've seen online I'm thinking its a current Balun ?
The man who cut the cable off his hoover and used it to make a choke balun. A good performing antenna beats a clean carpet
- Transwarp
- Call Sign: Viper
- Has thanked: 56 times
- Been thanked: 79 times
Re: Help needed to identify 1.1 Balun
- Buick Mackane
There is no DC short between the input or output terminals
- Transwarp
- Call Sign: Viper
It's a choke of sorts then I'd say.
Loads of vids on YT on chokes and baluns, one of l recall is called 'myth busting chokes and baluns' which l found informative.
- Buick Mackane
Pretty sure its a current balun trans as a voltage balun would have a direct DC short between is input & output terminalsTranswarp wrote: 16 Mar 2026, 13:45It's a choke of sorts then I'd say.
- Transwarp
- Call Sign: Viper
There's a lot of differing views on baluns and chokes, open, shorted, low resistance etc. Good luck fella.
- Transwarp
- Call Sign: Viper
Different ferrit makeup 'mix' for ithe intended frequency range use, coated wire to prevent arcing, good winding technique, low power saturation, minimum insertion loss, doesn't affect swr much when placed in-line, all the qualities of a good current balun slash choke.
A nano vna are good for checking baluns / chokes out
If l get some time to dig out I'll post a couple of pictures of a couple of baluns with my VNA connected to each.
- Buick Mackane
Well i emailed the manufacturer if anybody should know what it is they certainly should
- Transwarp
- Call Sign: Viper
You would think so, but this is just me, l doubt what suppliers / manufacturers respond back with at times because it's been dependent on who within has responded - engineer / tech Vs a manager example.Buick Mackane wrote: 16 Mar 2026, 14:39 Well i emailed the manufacturer if anybody should know what it is they certainly should
Maybe another more experienced with member will jump in on this at some point for you.
- Transwarp
- Call Sign: Viper
Judging from other simlar photos of it seems to be a current type balun. Apparently a ferrite rod with windings and how it's terminated on the input and output is a voltage balun.Buick Mackane wrote: 16 Mar 2026, 12:39 I know its 1.1 but is it a voltage Balun or Current ? Going by photos I've seen online I'm thinking its a current Balun ?
- Buick Mackane
The manufacturer got back to me and as suspected its a 1.1 Current Balun
- Transwarp
- Call Sign: Viper
Sorted then.Buick Mackane wrote: 16 Mar 2026, 16:33 The manufacturer got back to me and as suspected its a 1.1 Current Balun
Your post has reminded me that l have a FT240 / mix 43 core ferrite somewhere to make a CM choke / 1:1 balun up with. l bought a couple of baluns a while back and one is incorrectly labelled 1:1 when it's actually a 4:1, and the other turned out to be a voltage balun.
Sometimes making up your own bits of stuff is better than trusting in ready made bought stuff.
