UK Airport UHF Frequencies
Jtrickett93
Has thanked: 2 times
Post by Jtrickett93 »
I'm looking for UHF frequencies for UK airports. I have Manchester ground, and tower for both runways. But I'm after any other people know as my frequency scanner runs of UHF frequencies.
The airports I visit most are Manchester, East Midlands, Heathrow and Glasgow but I don't have frequencies for most.
Send any suggestions you have all are welcome.
Thank you in Advance
themysterioussea
Been thanked: 1 time
Re: UK Airport UHF Frequencies
Post by themysterioussea »
Most (If not all) of the UHF uplinks are between 455-456, If you scan that 1MHz range, you will easily find them!
26DT1496
Post by 26DT1496 »
BHX 455.475MHz
Paul
26-TM-1496 26-DT-1496 26-IDM-010
thedeerhunter270
Post by thedeerhunter270 »
Newcastle ground are on 455.750 and 455.850.
Chris64ex4
Post by Chris64ex4 »
Exeter Airport ground are on 459.575 mhz.
Ripshod
Call Sign: 26TM255
Has thanked: 26 times
Been thanked: 6 times
Post by Ripshod »
LBA 455.4875 MHz
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
DuncanH
Been thanked: 9 times
Post by DuncanH »
Liverpool John Lennon, the only ones I have.
Fire Service 455.8375 (DMR)
Ground Movements 456.850
Prestwick. I need some of these confirmed they are still active. I sent them to someone to check and they disappeared. All are NFM.
Tower Rebroadcast 455.625
Fire 455.700
Ground Ops 455.750
Security 453.0625
Handling Base 453.750
Check In 453.925
Buses / Car Parks 456.700
