Hello,
I'm trying to establish the GPS connection between two radios. They both show Member01 (host) in GPS. Anyone knows where i can change this? Haven't found any posts about it. Thanks!
73
Darko
Baofeng 5RH Pro GPS
- DX-Digger
- Call Sign: TM205
- Has thanked: 41 times
- Been thanked: 24 times
Re: Baofeng 5RH Pro GPS
They both cant have the same member name. one should be named Member02 (host)
Watch this TM1 Video demo of the gps function.
https://www.youtube.com/watch?v=W6y0FgpoSuw?t=1296
Also you have to be in gps mode and not radio mode
Watch the Demonstation to see how it works.
Check out the TM1 youtube channel for other great video reviews
https://www.youtube.com/@Transmission1
Hope that helps
Hope that helps
Darko
- New User
- Call Sign: S57BDM
Thanks for the link. The issue I have is that i can't find where i can set different name. Both radios have different names, but in GPS the both show the same - Member 01 (host). If i could fix that this would work.
- DX-Digger
- Call Sign: TM205
PM Simon on the following link he should be able to tell you how he did it.
https://www.transmission1.net/ucp.php?i ... ompose&u=2
cheers Digger
cheers Digger
Darko
- New User
- Call Sign: S57BDM
Thanks for the tip. Unfortunately I'm not allowed to see this link (member limitation i guess).
- DX-Digger
- Call Sign: TM205
If you click on quicklinks top left of this page then select members you should see Simon Transmission1
One other way maybe to add a comment under the youtube video and hope he replies that way.
There is also https://www.facebook.com/TM1UK
If you use facebook, message Simon that way.
Hope you manage to sort it
