hi there new here , i purchased 2 motorola DP4401e VHF EMEA online , seller is no where to be found .
i tried to program the with cps 2 , i was asked for a password .
after wondering and searching online i understood that i could some how reset the device with a Sample CodePlug for the model i have,
when looking into the sample folder inside the cps folder installation it wasnt there .
can anyone share / upload such blank codeplug sample for DP4401e VHF EMEA ?
thank you very much .
MDH56JDC9RA1AN
Motorola Codeplug DP4401e vhf wanted
Mototrbo2020
- Has thanked: 32 times
- Been thanked: 6 times
Re: Motorola Codeplug DP4401e vhf wanted
i cant...
i thought it was self explanatory
#1001798 no matching packages exist
same result in both version
CPS_2 2.146.122.0
CPS_2 02.128.144.0
okay so i found DP4401e plug from blank from cps 1.
i am on version CPS 2 2.146.122.0
however when trying to update it says "no matching package exist" i guess i need the firmware now
firmware is R02.21.01.0000
and when trying to use recovery it says
[#24032] To perform this operation CPS is required. Please
reinstall CPS and try again. If you continue to get this
message, please contact Customer Service.
Mototrbo2020
Yes you will need the firmware file in the cps directory.ron wrote: 11 Nov 2024, 04:33i cant...
CPS_2 2.146.122.0
CPS_2 02.128.144.0
