DIY HF vertical from tent poles?
26mb04
- Call Sign: 26DG01
Has anyone made a HF vertical from collapsible fibreglass tent poles? I have a spare length of these, I was thinking of running a wire down the middle instead of the elastic and terminating it at the base. It seems like a good way of getting height without carrying long pole sections around. I was going to use a hefty base mount so it doesn't fall over.
Sent from my GP300 using DTMF
- Black_Pirate
- Call Sign: 26TM034
- Been thanked: 2 times
Re: DIY HF vertical from tent poles?
Itresesting i, d keep the elastic and run a t2lt antenna made for your band... Even a carp/ kite pole is a few grams... Solid when guyed and you can run vertical, sloper or horizontal with the aid of a tree... Like that idea though..
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db.....
See FB page...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
