I have lost my copy of the gm339 software, If I recall it is R03.11.02.
I need to program some radios for IRLP, if any one can point me in the right direction to download this, it would be appreciated.
Regards
John vk3jd
Motorola gm339
wires
Re: Motorola gm339
If its an help, it's an Indian spec radio so more than likely an Asian cps instead of the European one you listed
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Re: Motorola gm339
yep.. different region, there is a 'region' changer for motorola radios.... floating around on the net, allows you to change the region settings for the radio, lots of the cheap 'ebay' gp380 sets are reflashed asia sets , .
there are 'modified' copies of cps with muli region ect.... PM sent
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
MotorolaMan
Re: Motorola gm339
Did you end up being able to get the software? im looking for the software to program my GM339 but cannot find the software, help would be appreciated .
