Icom 7400 Wideband Mod
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Has thanked: 9 times
Been thanked: 5 times
Post by MrWeetabix »
Does anyone have information on how easy this mod is (I dont trust Google results) or can recommend anyone to do this mod for me in the North East of England? Preferably having the work done here, rather than having it shipped away. Cheers
mr_h4ck3rm4n
Call Sign: MM6SGZ
Re: Icom 7400 Wideband Mod
Post by mr_h4ck3rm4n »
http://www.hampedia.net/icom/ic-7400-ex ... -rx-tx.php
7 small 0ohm SMD Links to remove, no f/w flashing or menu changes needed.
cheers
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
GW0DIV
Call Sign: GW0DIV
Post by GW0DIV »
Does the mod loose the band edge beep? I was contemplating doing this for 60M.
http://www.facebook.com/southwalesradio
http://www.radioclubs.net/rars/
Twitter: @GW0DIV
President of Bristol Channel Repeater Group
MrWeetabix
Admin
Admin
Call Sign: 26TM175
GW0DIV wrote:Does the mod loose the band edge beep? I was contemplating doing this for 60M.
Its a menu option, you can turn it on/off in there. I cant imagine that being removed from features just because of the physical mod. I'll let you guys know if/when I do the mod. Cheers for info :-)
Uncle Buck
Call Sign: G1UZN
Post by Uncle Buck »
GW0DIV wrote: 07 Dec 2011, 18:02 Does the mod loose the band edge beep? I was contemplating doing this for 60M.
Just seen this thread regarding this..
glad i did a google search and found Icom do NOT recommend it for the IC-7400.
ok for 40m but NOT 60m
I wonder how many radios have been damaged due to this ??
i won't bother doing my one owner mint 7400, i'll get a suitable radio for 60m.
