FireService CH07
deadite66
- Call Sign: 26TM7373
- Has thanked: 2 times
- Been thanked: 2 times
FireService CH07
Started hearing more DMR being used on this channel and what i've heard has been pretty weird, i'm sure its can't be local.
anyone else heard it and has any ideas?
SDRPlay RSP1A + CrossCountryWireless Loop
Icom IC7410 + thunderpole boomerang
Retevis RT90 (opengd77) + Diamond x50
Yupiteru MVT-9000MKII, Baofeng DM-1801 (with opengd77)
AdrianNR30
Re: FireService CH07
Heard this too. Last couple of evenings (Wed/Thu 28/29 Sep) it seems to have been used for an exercise I believe from what I heard at/near Great Yarmouth rail station. The talkgroup & colour code matched the fire service national allocation for channel 7 (Service allocated). I was only getting one sided conversations, what I was getting was coming in fairly strong so I assume that side was coming from some sort of higher powered control unit and I was not receiving the handset replies. As an aside I often hear some sort of comms on 449.3125 re movement of rolling stock, I assume from the sidings at Great Yarmouth, Thursday they complained they couldn't do a movement as there was a fire engine in the way!
- Metradio
- Call Sign: G7HID
Fire Appliance radio switched into mobile repeater mode, Control Room communications repeated out to on scene handhelds...AdrianNR30 wrote: 30 Sep 2022, 13:19 ......... I was only getting one sided conversations, what I was getting was coming in fairly strong so I assume that side was coming from some sort of higher powered control unit and I was not receiving the handset replies......
Mike
deadite66
it does make more sense its part of a training exercise someone at work suggested the same, one of the things i heard would have been national news if it was real.AdrianNR30 wrote: 30 Sep 2022, 13:19 Heard this too. Last couple of evenings (Wed/Thu 28/29 Sep) it seems to have been used for an exercise I believe from what I heard at/near Great Yarmouth rail station. The talkgroup & colour code matched the fire service national allocation for channel 7 (Service allocated). I was only getting one sided conversations, what I was getting was coming in fairly strong so I assume that side was coming from some sort of higher powered control unit and I was not receiving the handset replies. As an aside I often hear some sort of comms on 449.3125 re movement of rolling stock, I assume from the sidings at Great Yarmouth, Thursday they complained they couldn't do a movement as there was a fire engine in the way!
deadite66
Started Hearing DMR being used the last few days on this channel, showing a great yarmouth id.
AdrianNR30
From what I have been able to monitor Norfolk Fire & Rescue Service (in Great Yarmouth anyway) are primarily using analogue still, only noted DMR active when incidents involve the attendance of cross border (i.e. Suffolk) appliances.
- Call Sign: G4RMT
- Been thanked: 18 times
Suffolk have some tech savvy firefighters who own some very nice digital radios that might possibly be doing multiple jobs. VHF and UHF capable, and DMR too. If you owned your own radio that could access two separate work radio networks, would you? I think I would
- Call Sign: G4RMT
Suffolk are reverting to analogue for their fireground radios. They’ve found the difficulties of lots of people working close where the delayed echos feedback outweighing the benefits. Simply didn't work for them.
deadite66
Been hearing a lot more DMR this week, maybe they are starting to switch over.
deadite66
Heard DMR on Command and Breathing guess were digital here now, time to update my channels.
leonsimmons5
- Has thanked: 1 time
- Been thanked: 1 time
Yeah they have fully switched now, and it was delayed by a month. I’ve logged quite a few Rid’s (GYAP1, P7,P8, GORP3, L1, ACLP8) some do have alias enabled
