Its the smallest mobile radio I've ever seen. Roughly 4 inches Square. Power output is bang on Spec. 5-10-17 Watts. Had an on air check from a station 30 miles away running 5 watts and all was good. 199 Channels. And easy to program from the front panel buttons. Including repeater offsets and Sub tones etc. It can be programmed via a PC. But the only thing I've found so far that can't be done via the front panel is programming repeater names. So you don't really need to hook it to a PC.. RX Audio is nice and loud and clear enough. The display is bright and easy to read given its small size. Although some smaller characters can be a struggle..Its a menu driven radio apart from the Volume control..
Downsides ?
Sensitivity isn't as good as my Icom 706 mark 2 or my Key PMR radio. Specs say 12db SINAD 0.25uv (Update its on par with my 706)
The scan speed isn't the fastest. But not an issue with me.
The mic plugs into the PCB internally. But you could chop the cable where it leaves the radio and fit an RJ45 socket if you wanted too.
The signal meter comprises of 4 Horizontal bars stacked on top of each other. Which don't seem to equate to anything. So as a signal meter its pretty useless.
When changing frequency or Channels via the mic buttons there is the odd 'Stutter'' But its hardly problematic. And pretty common with cheap radios.
Ive read these radios can get hot. But i won't be running more than 10 watts. And I'm not one for long overs. Plus i have a few small fans if needed.
There is also a UHF version. And a low band version. The low band version is a bit rarer and costs more. The ''V'' version covers 136-174MHz.
So all in all first impressions are good. All i wanted was something cheap & cheerful to leave on in the background to monitor 2m And for that it suits the bill... Will it last ? Watch this space
