In reply to both:
The 8.33kHz scheme can (and does) confuse. My scanner '
corrects' 135.58Mhz to 135.757Mhz, and that correction did cause my confusion, until I did the research in order to understand what was going on.
During my childhood (I lived right next to Cottesmore), I attended a great deal of Airshows, becasue my Farther was a huge Military Aircraft buff. It was during one of those occasions that I saw and heard a hand-held frequency scanner, and I was fortunate enough to have one gifted to me. Back then, it seems that AT comms was a little different (unless my memory is not up to snuff) as I seem to recall that the "Tower" would be named (at least during the initial contact) and thus one would know the ident of the frequency. Indeed, I had a note book full of this info and would listen in and search for stuff at home, also.
My point to that little trip down memory lane, is that I no longer hear any ident info and as such, it's not so easy.
https://adsbexchange.com/ is real useful, as I can see what Aircraft are where, and use that as a guide as to which Airfield the comms will be with, when say, there's an altitude or heading change for example.
So, in conclusion, I know that some of the freqs that I have seen on lists (some of which are real long and are even c&p from other sites) are as much about the location as they are about the frequency.
I have a new (used) computer being delivered next week; one that I can use purely for my Radio Comms Hobby. I don't use Microsoft systems for anything (I'm a Linux user), but it seems that all software for this type of stuff is designed for MS systems, which is understandable. Yes, I've tried the old and favored workarounds, but there's always some issue or other, so for the sake of £40 for a Lenovo Windows 10 Laptop, it seems nuts not to simply go for that.
I'll report back about the Squawker PC software, if anyone is interested in me doing that, just as soon as I have it all up and running.
Edit to add:
milly wrote: 06 Jun 2026, 16:57
Channel 135.58 isn't re-used?
Thinking on about what I posted and your reply to that: I accept what you say, as I'm sure that your experience and knowledge is way better than mine, so it's entirely possible that the info that I've found via internet searching is simply out of date, and that freq is no longer used by London/Gatwick, and has been 'reassigned', rather than 'reused'; 'Semantics', possibly.
This is a very small sample of a 2000+ line list that I found...
Code: Select all
118.50 Dublin Radar
118.50 Heathrow Tower
118.50 Newcastle Radar
118.525 Mantson Radar
118.55 Humberside Tower
118.55 Jersey Radar
118.575 Manchester Approach
118.60 Dublin Tower
118.625 Brough Approach
118.625 Manchester Tower
118.65 Bournemouth Radar
118.70 Edinburgh Tower
118.70 Heathrow Tower
118.70 Shannon Tower
118.725 Paris ACC
118.775 London ATCC
118.80 Cork Radar
118.80 Glasgow Tower
118.825 London TMA/ATCC
118.85 Tees-Side Approach
118.875 Oxford Tower
118.90 Guernsey Radar
118.90 Isle of Man Tower
118.90 Kemble Approach
118.90 Lossimeouth Tower
118.90 Tain Range Info
... so either freqs are reused at different locals, or this kind of info is grossly inaccurate.
