Guide to replacing Signal meter bulbs with LED's
1968neil
Been thanked: 1 time
Re: Guide to replacing Signal meter bulbs with LED's
Post by 1968neil »
LEDs can be dimmed but you’ll need to use PWM.
(Pulsed width modulation)
Basically varying the duty cycle with a pot is all that’s needed if you use a small microcontroller.
I’m happy to knock up a circuit and software if anyone is interested in having a go ?
Neil
Rascal
Post by Rascal »
PWM? - Wont that cause interference?
lbcomms
Been thanked: 9 times
Post by lbcomms »
Rascal wrote: 13 May 2026, 06:28 Wont that cause interference
Not if it's done correctly. Being aware of good cable routing, using shielded cable, or using frequencies above what's audible are 3 methods that can be used alone or in combination depending on the circuit and application.
