Stryker
- Nitehawk
- Been thanked: 1 time
Stryker
I have a Stryker SR955hpc+ radio, have just bought a Stryker 76nc microphone, but it's wired for cobra, can any of you guys tell me the mic wiring for the microphone, if you can tell what wires go in what pin number that would be great. What colour wire for what pin number. Cheers Dave.
- Nitehawk
Re: Stryker
Yes I've seen this, but .when I press the ptt button nothing happened, yes I've put .a new battery in.
- Stronty
- Has thanked: 56 times
- Been thanked: 18 times
Re: Stryker
When you say " bought a Stryker 76nc" is that brand new or second hand? only ask as if not new i'd suggest you check the Mic side wiring.
- CookieRaider
- Call Sign: 26TM506
- Has thanked: 14 times
- Been thanked: 10 times
Re: Stryker
Looking at the mic wiring on the www assuming the wiring is std uniden as its cobra, to change over to the Stryker SR-955HPC swap pins 1 and 2 over on the plugNitehawk wrote: 08 May 2026, 13:48 I have a Stryker SR955hpc+ radio, have just bought a Stryker 76nc microphone, but it's wired for cobra, can any of you guys tell me the mic wiring for the microphone, if you can tell what wires go in what pin number that would be great. What colour wire for what pin number. Cheers Dave.
Stryker SR-955HPC
Pin 1: Shield (Ground)
]Pin 2: Yellow (Audio)
Pin 3: Red (Transmit / PTT)
Pin 4: White (Receive)
Uniden/Cobra
Pin 1: Audio (White or Blue)
Pin 2: Shield/Ground (Bare wire or Braided)
Pin 3: Transmit/PTT (Red)
Pin 4: Receive/Common (Black)
or get a multi-meter out
Winner of the coveted 'In Before The Lock' competition 07 Jan 2013
Winner of the coveted 'In Before The Lock' competition 24 June 2013
inaugural champion of the coveted "Putting sex before trivial internet games" award November 2013
