Dodgy CB Mods. What's the worst you've seen ?
Buick Mackane
Moderator
Moderator
Has thanked: 37 times
Been thanked: 18 times
Re: Dodgy CB Mods. What's the worst you've seen ?
Post by Buick Mackane »
Not a Mod as such but I remember a pal who lived with his parents at the time going into the loft with a silver rod and a hammer and punching a hole in the roof slates with the hammer and then he stuck his silver rod through the hole. Job done. Needless to say his dad went bananas. Now that is a bodge :D
NightProwler
Has thanked: 9 times
Been thanked: 32 times
Post by NightProwler »
There was someone not far from me in the mid 80's who had a Thunderpole in his attic, Well the groundplanes were the top section was sticking out the top of the roof through a hole he made.
Mudslinger
Has thanked: 1 time
Post by Mudslinger »
This is a Uniace 100 which I have here now.
Check out the quality of installation of the noise squelch. Amazingly the radio works quite well, but there is no squelch at all just constant white noise.
I am going to rip it out and wire it back to standard when I get the time.
109 Jim
Been thanked: 1 time
Post by 109 Jim »
Was listening to the Dimwit net on T5 and one of them was rather excited talking to his mate , he was using a A99 and a good quality coax M&P or ? i cant rem , but his SWR was 1.5 and he couldn't bring it down and he wanted 1.1 , rather excitedly he was saying he has fixed it and all he did was take off the good quality coax and replace it with 50m of the thinnest cheapest quality he could find and his SWR went to 1.1 without touching the A99 and he would go round at the weekend and do the same to his mates {bnghd} :crazy: :clap: :D
Transwarp
Call Sign: Viper
Has thanked: 17 times
Been thanked: 22 times
Post by Transwarp »
Their coax will probably perform better as a wire antenna than the A99 anyway :lol:
109 Jim
Post by 109 Jim »
Transwarp wrote: 11 Feb 2026, 09:47 Their coax will probably perform better as a wire antenna than the A99 anyway :lol:
:clap: :D :D
Buick Mackane
Moderator
Moderator
A wee bit off topic ( I will send myself a warning later) :D
The guys who count a mode change as a new set of channels. My rig has 1000 channels :lol:
Transwarp
Call Sign: Viper
Post by Transwarp »
Buick Mackane wrote: 11 Feb 2026, 12:32 A wee bit off topic ( I will send myself a warning later) :D
Y'know forgot about that, good one.
40ch AM + 40ch FM + 40ch USB + 40ch LSB + 40ch CW + 5 splits on each mode. Multiply that per band: SSL, SL, Low, Mid, High, SH, SSH = 1575 channels!! :thumbup:
:lol:
Antoni
Call Sign: Triac
Been thanked: 12 times
Post by Antoni »
err... hang on.... USB and LSB are different channels. One above and the other below the channel frequency They can carry two different conversations.
But you knew that...
(Futher off-topic)
Transwarp
Call Sign: Viper
Post by Transwarp »
Antoni wrote: 11 Feb 2026, 16:19 err... hang on.... USB and LSB are different channels. One above and the other below the channel frequency They can carry two different conversations.
(Futher off-topic)
C'mon, stop splitting hairs - or bands in this case :lol:
Buick Mackane
Moderator
Moderator
Well technically yes. On 27.555 for example USB would be 27.558 LSB 27.552 give or take. But still within the same frequency range
Mudslinger
Has thanked: 1 time
109 Jim wrote: 11 Feb 2026, 08:29 Was listening to the Dimwit net on T5 and one of them was rather excited talking to his mate , he was using a A99 and a good quality coax M&P or ? i cant rem , but his SWR was 1.5 and he couldn't bring it down and he wanted 1.1 , rather excitedly he was saying he has fixed it and all he did was take off the good quality coax and replace it with 50m of the thinnest cheapest quality he could find and his SWR went to 1.1 without touching the A99 and he would go round at the weekend and do the same to his mates {bnghd} :crazy: :clap: :D
I had a mate that did this. He bought some new coax, and because his SWR was a lot worse he went back the old coax.
I tried to explain that his SWR was the same on both, but he was getting better readings on the old coax because the reflected power was being lost.
It also explained why he managed to kill a couple of linears in quick succession (the real SWR was about 2.5:1)
lbcomms
Been thanked: 8 times
Post by lbcomms »
Phantom Communicator (Aussie Cybernet) - Wrong knobs (Jaycar cheapies), NB and ANL front panel switches rewired for more channels, and 8 more extra channel switches mounted into the top of the case. How many channels does someone need?
Transwarp
Call Sign: Viper
Post by Transwarp »
That's some mod.
