CB mobile antenna on car high SWR
StormShadow
Has thanked: 17 times
Been thanked: 8 times
Post by StormShadow »
I've got a mate who wants to get back into CB, he is planing on having a mobile setup in his car, its an older car with a metal body mag mount is good, good coax and the CB whip is one of those modulator types. Can not get the SWR down enough to a safe level for TX. I'm guessing undoing the grub screw and adjusting the whip length slightly might help but if not then I don't know.
I'm just wondering if a tuner is required for mobile setups?
Antoni
Call Sign: Triac
Has thanked: 15 times
Been thanked: 36 times
Re: CB mobile antenna on car high SWR
Post by Antoni »
If you need a tuner on a set-up like that something is wrong. It's a simple set-up, check security of plugs and look for short circuits with a meter.
If you take the antenna off the mag mount there should be no short-circuit across the plug. If you put a short-circuit on the mag-mount - either across the SO-239 socket or from the central stud to the mag-mount metalwork you should see a short circuit at the plug.
Bear in mind that any fault might come and go with gentle wiggling (first) or more agressive wiggling (last).
For there to be any mileage in adjusting the antenna's tuning, there would have to be a better SWR on either Ch 1 or Ch 40. If there is a difference, put your hand close to the antenna while testing. If the SWR improves lengthen it. If it gets worse shorten it.
Or none of the above.
Слава Украине !
StormShadow
I did all that and everything test good I even test each end of the whip for continuity, I think the whip is either too short or too long. Tested with a 9ft tank whip and SWR was fine but you can't drive with one of those on the roof when putting the mobile whip back on SWR is high so clearly an issue with the mobile whip.
scanhermit
Has thanked: 48 times
Been thanked: 75 times
Post by scanhermit »
Is it a long modulator style twig or one of those miniature ones like the Thunderpole Atom? I hear the shorter ones are harder to SWR.
If a long one, it may not have been set up properly in the factory and may need adjusting via the grub screws or (whisper it) cutting.
I've got a PNI ML145 that is ok on EU1 but 1:3 on UK 40. Shortening via the grub screws hasn't worked so it looks like I'll have to cut the whip. I've just been too chicken to do it yet.
StormShadow
scanhermit wrote: 27 Dec 2025, 10:17 Is it a long modulator style twig or one of those miniature ones like the Thunderpole Atom? I hear the shorter ones are harder to SWR.
I would need to trim the whip or add the inside of a junction block to it if it needed slightly more length. I wouldn't attempt to trim it without an analyzer because SWR doesn't always give you accuracy.
Mudslinger
Has thanked: 12 times
Been thanked: 45 times
Post by Mudslinger »
A few months back I bought the Moonraker version of the Thunderpole Atom.
It was impossible to SWR on my car, I even fitted a different whip which was lying around so that I could shorten it. I tried to send it back but they were not having any, so don't buy one of those.
Moonraker stuff was always rubbish and it seems that nothing has changed.
scanhermit
I remember that saga! I was rooting for it to work.
Duly noted!
The Thunderpole 2ft superflexi apparently tunes well even on difficult setups.
scanhermit
I read somewhere that an analyser tells you what the antenna should do but an SWR meter tells you what it's actually doing. I don't know the truth of this so am open to being educated.
scanhermit
Latest Thunderpole mini allegedly pre-SWR'd:
https://www.thunderpole.co.uk/small-cb- ... uttle.html
Nice fat coil!
StormShadow
scanhermit wrote: 28 Dec 2025, 20:17
SWR will give you an idea by telling you its reflective power coming back, there are so many other factors involved and an antenna that gives you a low SWR doesn't always mean it performing well, or as it should perform. An analyzer will tell you so much more.
StormShadow
Mudslinger wrote: 28 Dec 2025, 19:14
Your right Moonraker stuff isn't very good although I'm sure many will swear by it and say Moonraker is a top brand. My experience differs. A good example of this was when I bought a Moonraker antenna and the coax braid was shorted to the center which it wasn't supposed to be and the coax was also of poor quality. Easily fixed with some better coax and better solder joints.
scanhermit
StormShadow wrote: 29 Dec 2025, 07:30
Ah, thanks. An analyser must be essential for building ones own antennas but I didn't think of using one for commercially manufactured twigs.
