Motorola DP4400e Codeplug
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
Looking for a blank to start my DP4400e, or one that I can write over.
UK Amateur use.
Thanks.
Kev S
Mototrbo2020
Has thanked: 29 times
Been thanked: 3 times
Re: Motorola DP4400e Codeplug
Post by Mototrbo2020 »
Just overwrite the one in the radio?
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
Sadly unable to read from the radio with version 16 build 828.
Mototrbo2020
What firmware is it running?
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
R02.20.01.0000
Mototrbo2020
You will need cps 2 then todo it.
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
OK thanks, not having much joy with that either.
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
Is it possible to go back to an earlier firmware?
Mototrbo2020
G7VNQ wrote: 20 Mar 2025, 18:59 Is it possible to go back to an earlier firmware?
Yes can be done via Depot I believe but not advised.
Mototrbo2020
Pmed you.
