NEED HELP YUPITERU MVT-7100
butech
I RESET MY SCANNER AND NOW HAVE A PROBLEM. THE SCREEN IS SHOWING THE FACTORY CONDITION IE 20MZ 1440000 FM BEEP AND THE BATTERY INDICATOR FLASHING. PROBLEM IS THAT IT IS STUCK ON 1440000 AND ONLY THE VOLUME CONTROL WORKING. NO BACKLIGHT SQUELCH OR BUTTONS OPERATING, I HAVE FULLY CHARGED BATTERIES INSERTED AND HAVE TRIED DIRECT VOLTAGE.
CAN ANYONE ADVISE OR RECCOMEND A REPAIR AGENT.
THANKS
DENNIS
Try not to use caps all the time ~ Mod Fez
THANKS
DENNIS
Hertz
- Banned
Re: NEED HELP YUPITERU MVT-7100
Is there a yahoo group for Yupti's ? I would be surprised if there is not & they can be invaluble.
If they tried to change our national anthem would people stand for it?
And ball points....Should we award them?
Bob Monkhouse.
Bob Monkhouse.
neil-c
There is a keylock button on the left hand side of the scanner, has this been switched on? This could cause all the problems you have described.
chickenzown
- Call Sign: chickenzown
My mvt-7100 has exactly the same problem you describe, did you find a solition?
- Minus1
Oh no, mine too. Dead, the only thing I can do is reset it, whereupon "Clear" appears. Stuck on 144.0 with constant maximum signal, no buttons work. Power supply adaptor seems to have failed too, I wonder which came first?
Still, it's lasted some 20 years...
Marcotte
- New User
Hello everybody,
I allow myself to ask for your help because, after a fall of the scanner, I had the following failure : the "squelch" no longer works despite the potentiometer fully turned.
I tried first a "reset" without success. I thought then that it could be the squelch potentiometer or the "Monitor" button on the side that could have suffered from the fall.
Always the same problem despite the replacement of these elements. Would it be a soldered component on one of the integrated circuits that jumped ? Have you ever encountered this problem on your Yupiteru?
Thank you for your reply.
Regards,
Alexandre
Regards,
Alexandre
- Werthers
Its possible that you may have a small fracture on the board somewhere or one of the components on the board has broken off. The squelch potentiomete pins may not be making good continuity to the board.Marcotte wrote: 22 Sep 2019, 12:44 Hello everybody,
Regards,
Alexandre
Marcotte
- New User
I'm afraid this is the right option
Anyway, thanks for your answer
taximan
- New User
- Call Sign: 2E0YTT
https://www.youtube.com/watch?v=SSFlkAxZMs4&t=33s try this for repare
Marcotte
- New User
Skanking333
- Banned
Easy, press and hold the scan button, switch on
Keep the scan button depressed for 6 minutes
