New to scanning in Hampshire / Wiltshire area
Scanning radio frequencies for the South East
tomos
Post by tomos »
Hi All
After some great advice on scanners I am trying to setup my 800xlt. Are the hampshire frequencies listed in the locked tread still
up to date. I am in the Andover / Salisbury area. If anyone has some frequencies I would be very gratefull thank you. I am hoping for Civil and military air , pretty close to Thruxton aiport where the IOW air ambulance operates, middle wallop air field, Andover chantry center PMR ? Salisbury plain etc. I am also trying to hunt them out so can hopefully put a file togther for other users in this area
Thank you
wind in the antenna
Re: New to scanning in Hampshire / Wiltshire area
Post by wind in the antenna »
tomos wrote:Andover chantry center PMR ?
0296238 Business Radio
Business Radio (Technically Assigned)
Shop Safe Limited
TX 453.1125 MHz
RX 459.6125 MHz
SU 364 455
Details for licence number 296238
Start a new licence search
Licence holder details
Licence holder Shop Safe Limited
Contact name Mr Philip Blenkhorn
Telephone 01284-827272
Email Len@shopsaferadio.com
Address Unit 1 Brickfields Business Park
Old Stowmarket
Woolpit
BURY ST. EDMUNDS
IP30 9QS
Licence details
Licence class Business Radio (Technically Assigned)
Frequencies and locations
Location(s) Channel(s)
SU 364 455 TX: 453.1125 MHz
RX: 459.6125 MHz
Bandwidth: 12.5 kHz
I'm a radio armature who made the switch to ariel none-bio
New Face in Hell
Tony in Brighton
26TM9480
26FB298
G7TXU
tomos
Post by tomos »
:) Thank you that, I will give it a go later. Anyone know the Hampshire and IOW air ambulance, or do they use a generic frequency
freelander2
Post by freelander2 »
Not sure about the "in the air" frequency, possibly Airwave for comms to Police, but tune to Thruxton tower. I caught 99 coming in just last week.
Midland 42 Multi, Alan Spkr Mic, Magmount & Mini Springer, Sharman 9' Tank Whip, Thunderpole Voyager.
Bearcat 3500xlt & Watson 881 Supergainer.
2xBinatone 950 pmr446
pterodaktyl
Post by pterodaktyl »
Have a look at: http://www.milscanners.co.uk/frqdb.html
As well as the frequencies for your local airfields like Boscombe Down, do a search of the database for "british army". This will give you the frequencies used by Forward Air Controllers to talk to Close Air Support aircraft during exercises on Salisbury plain. You should be close enough to hear the pilots, even if you can't pick up the FACs.
Also do a search for "london" and you'll get the frequencies for London Military at Swanwick - these are the controllers who provide en-route ATC services to military flights in English/Welsh airspace.
Tom
wind in the antenna
I'm not an airband scanner but you could try138.70000 and 132.6500 MHz the Sikorsky rescue helos from Lee-on-Solent
New Face in Hell
Tony in Brighton
26TM9480
26FB298
G7TXU
paull73
New User
New User
Post by paull73 »
Does anyone know any for Basingstoke, I have tried using the ofcom site, but it does not give me local ones..... I am after pubwatch / shop watch / street pastors Basingstoke.
Minus1
Post by Minus1 »
paull73 wrote:Does anyone know any for Basingstoke, I have tried using the ofcom site, but it does not give me local ones.....
You can't be using it correctly.
Search between 68 and 470 MHz, then ciick "View results on a map".
OFCOM don't have the gumption to exclude nationwide licences from search results, which includes all the Simple UK licences. {bnghd}
Have a look at licence 0863132 too. No idea what transmissions are used, could be digital.
NToombes
Call Sign: M0CJM
Post by NToombes »
paull73 wrote:Does anyone know any for Basingstoke, I have tried using the ofcom site, but it does not give me local ones..... I am after pubwatch / shop watch / street pastors Basingstoke.
Wow, are you a newbie from Basingstoke? I am out in Oakley so fairly close to you!
Neil
Oakley, Basingstoke, Hampshire
M0CJM, 26-TM-749
Kenwood TS2000, Yaesu FT8900,
Icom IC-R8500, Yaesu FRG-100, Uniden UBC800XLT
Uniden UBC780XLT, Uniden UBC92XLT & Uniden UBC3500XLT
Half Size G5RV, Maldol Base Discone, Diamond V2000 vertical, Buddipole Deluxe.
