Code: Select all
GB WTS
Anyone know what that is?
It's kinda intermittent, so if you want to hear it, you'll need to be patient. I've tried to pin down any pattern to the TX times, but there's none that I can determine, save for it seems to repeat apx 10 to 15 minutes between transmissions (e.g: 10:07 then 10:12 and 15:00 then 15:16, but this does vary, from day to day).
