130.200 MHz
rob42
Has thanked: 54 times
Been thanked: 22 times
130.200 MHz
Post by rob42 »
Does anyone know which Airfield, in the North East, uses 130.200 MHz ?
The only ones I can find are Chivenor and Cottesmore, but I can't see that I'd be able to get a reception from those, given the distance.
QTH: Durham UK
Scanner: Uniden UBC125XLTC + Moonraker Skyscan Mobile Antenna
Software: Scan125 Control Program Suite
(http://www.nick-bailey.co.uk/scan125)
with my own scan125-frequency.log Monitor bolted on.
Transceiver: Baofeng GT-5R + NAGOYA NA-771
License Level: Pending
Ripshod
Call Sign: 26TM255
Has thanked: 34 times
Been thanked: 13 times
Re: 120.30 MHz
Post by Ripshod »
130.200 LBA Tower
If you're picking that up worth listening on
118.030 LBA ATIS
134.580 LBA Approach
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
121.800 LBA Deliveries
131.680 LBA Ops
125.380 LBA Director
455.4875 FM - Local repeater for ground crew
** Edited to include director and correct some frequencies
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
rob42
Re: 130.200 MHz
Post by rob42 »
@Ripshod: Ty. I'll pop those into my AT Bank, and see what comes back.
QTH: Durham UK
rob42
Re: 130.200 MHz
Post by rob42 »
@Ripshod: Reporting back that I have RT on 131.550
Is that part of the LBA also?
QTH: Durham UK
rob42
Re: 130.200 MHz
Post by rob42 »
@Ripshod: Ah! There we go. Your updated Freq of 130.200 now ties in with my topic title. Thank you very much; it's far more likely that I'd be getting RT from LBA, given that it's much closer to me.
QTH: Durham UK
Mototrbo2020
Has thanked: 30 times
Been thanked: 4 times
Re: 130.200 MHz
Post by Mototrbo2020 »
LBA tower is 120.3
Ripshod wrote: 31 May 2026, 05:38 130.200 LBA Tower
118.030 LBA ATIS
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
131.680 LBA Ops
rob42
Re: 130.200 MHz
Post by rob42 »
Mototrbo2020 wrote: 31 May 2026, 09:42 LBA tower is 120.3
Okay, ty for that. Now I'm a little confused, but then again, the chatter that I heard yesterday on 130.200 did not sound like the typical chatter that one hears from ATC. It sounded more like ground crew, tbh: there was talk about refueling and engine starting, etc.
QTH: Durham UK
Ripshod
Call Sign: 26TM255
Re: 130.200 MHz
Post by Ripshod »
118.030 LBA ATIS
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
131.680 LBA Ops
You are, indeed, correct.
I blame number dislexia. Seems I've misled the op somewhat.
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
rob42
Re: 130.200 MHz
Post by rob42 »
Ripshod wrote: 31 May 2026, 15:35 ... Seems I've misled the op somewhat.
Not a worry; mistakes happen all the time. In fact, it's a quite refreshing to find someone who admits to a error; in this day and age, that has become a rare thing indeed.
QTH: Durham UK
