I have a couple of deaf radios in need of realignment. They were programmed to 2 meters but the receivers need adjusting for the frequency. I don't have the right test equipment to tune them up and I really don't want to spend hundreds on equipment that I'll rarely use.
I need to build something simple that gives a weak signal on 145MHz so that I can tune the receiver to the loudest sound.
What would be the best way to align the receiver?
Deaf radio
- Has thanked: 7 times
- Been thanked: 20 times
Re: Deaf radio
Use another radio. TX to dummy load. Move it away to get desired signal level.
- DX-Digger
- Call Sign: TM205
- Has thanked: 41 times
- Been thanked: 24 times
Re: Deaf radio
friend of mine used to put a handheld on low power and a rubber band around the ptt and put it inside his fridge.
worked a treat.
worked a treat.
