decoding software
gerald123
decoding software
does any one know of a good decoding software........ i am using pocsag at the moment but not getting mutch.. i am interested in [ acars . navtex . pagers ] and any good frequencies.........
DistantSignal
Re: decoding software
Gerald, what do you mean you're not getting much? Much in the way of signal? Or you want more messages?
CHECK OUT MY RADIO BLOG
http://distantsignalradio.blogspot.co.uk/
My Youtube
https://www.youtube.com/channel/UC67TJP ... i2h1aaSO6Q
My Youtube
- B5566
gerald123
i am getting a signal. but the only mesage i get is unknown sync header b368 a6c6 aaaa 4e97 [continued message-fragment #3header ]DistantSignal wrote:Gerald, what do you mean you're not getting much? Much in the way of signal? Or you want more messages?
DistantSignal
What piping software are you using?
My Youtube
My Youtube
gerald123
gerald123
finaly got sdr sharp working with pdw decoder. i followed a link on utube to set it all up GREAT STUFF
- kr0ne
You really need to use the line level input (usually a blue socket), rather than the mic level one (usually a red socket) as that has a pre-amp in the signal path...gerald123 wrote:i am using audio lead from radio scanner to microphone input on pc.
If you're using a laptop or crappy dongle that only has a mic input then try turning the level right down for that input using the sound mixer in Windows, or whatever you are using.
