gp320 password
dieselman
gp320 password
i bought a gp320 on ebay and when i go to read the radio it asks me for a password and wont let me go any further until i give it ..i contacted the seller and he said he has no knowledge of radios and does not know it ..what are my options here guys?? ..all help appreciated thank you ..bf
- benw18
Re: gp320 password
Open an archive codeplug and write it over the top of the existing codeplug... Assuming you have the right CPS version and the codeplug has not been set to 'read only' this will work.
If that fails you need to read the RAM from the radio and 'find' the password.
- benw18
Re: gp320 password
In the archive you need to look for- p_uhf1_n0
EDIT- Assuming you are programming UHF
- Been thanked: 3 times
Re: gp320 password
I take it you tried the obvious?
1234
0000
Do you get unlimited attempts? If so then it's scary the amount of four digit passwords that fall in the range of 1940-2000
1234
0000
dieselman
Re: gp320 password
how do i overwrite the codeplug???i never done this before ,and it is uhf im programming ,thanks for all the help guys you guys on this site are the best
- benw18
Re: gp320 password
The password is not limited to numeric, it can be alpha numeric and a maximum of 8 characters. Yes you get unlimited attempts, but after each wrong entry the connection between the radio and PC drops. The radio needs to be read every time you get the password wrong- which can take 2-3 minutes if they are heavily programmed.
All you need to do is find the codeplug in the archive folder (the exact one I have told you). Connect the radio to the PC and write it.
dieselman
Re: gp320 password
tried this bro and it keeps telling me incompatibilities found, im using CPS R03.11.16_EN ....sorry for bothering you again but im not gona let this beat me ..cheers..bf
- benw18
Re: gp320 password
What are the errors?
It could be a case that your Firmware is too old (on the radio itself) and the CPS will not write the newer firmware codeplug to your radio- as the radio does not have a new enough codeplug version. If this is the case you need to either flash the radio to a newer FW version, or, use an older CPS.
If you have never flashed a Motorola radio before, approach with caution- it is far too easy to turn your radio into a paper weight (and then cost £100 to repair)! Use the PROPER kit, or, go to a dealer and get them to do it (some will, some wont).
Without being hands on with the radio itself its hard to work out the exact problem, but my money would be on the the codeplug being too old on the radio to accept a newer codeplug.
dieselman
Re: gp320 password
yes i think your right the codeplug is to old ,i will try and get hold of an older cps and approach with caution..thanks again for all your help...ill let you know how i got on..bf
dieselman
Re: gp320 password
hi ben ,i got that radio sorted,the software i was using was to recent of a version,i got a hold of D03.02.01_EN and i overwrote the codeplug like u said and i was able to read and write it no problem ,thanks so much for running through this with me i really appreciate it...brian
gans
Re: gp320 password
Hi Brian, I need codeplug version R03.05.00_EN PMUE1443B and R03.02.15_EN PMUE1443A. Please help.
