Motorola Codeplug wanted
Reegz
Call Sign: MW7GIA
Re: Motorola Codeplug wanted
Post by Reegz »
Im having the exact same issue. I've PM'd you also PeakHour, bit cheeky i know but im at my wits end.
Expensive paperweight at the moment
Reegz
Call Sign: MW7GIA
Post by Reegz »
Werthers
Post by Werthers »
Just to clarify a codeplug isn't the programming software. They are two different things.
You need the appropriate Motorola CPS programming software for your radio, a blank code plug can be found within the programming software or easily created using the Motorola CPS.
What programming software are you looking for?
AMX97
Post by AMX97 »
I've got the CPS for DM and DP radios but the software didn't come with blank code plug for the DP4400 on UHF as my boss bought a bunch used and it turned out they had passwords on but the seller was adamant there wasn't any and we couldn't get a blank code plug to write to it
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
Baofeng UV-9R
uniden ubc125xlt
Moonraker M10
bigboyblue
Post by bigboyblue »
AMX97 wrote: 18 May 2021, 19:55 I've got the CPS for DM and DP radios but the software didn't come with blank code plug for the DP4400 on UHF as my boss bought a bunch used and it turned out they had passwords on but the seller was adamant there wasn't any and we couldn't get a blank code plug to write to it
cick recover. voila. blank non passworded radio.
Jabkotsw
Post by Jabkotsw »
HELLO CAN ANYONE HELP ME ??? I have motorola dp4400e and try to use cps 16 (823) cps v 2.0 newest version but i cannot connect with my device because showing message codeplug device not supported ....???? how can i sort this out ?? thank You guys for any help .. my email is jabko_ts@o2.pl if anyone got this codeplug and can send it to me....
Tittifer
Post by Tittifer »
I've read all this thread and i still don't know what a codeplug is :?
bigbloke
Been thanked: 3 times
Post by bigbloke »
Tittifer wrote: 10 Oct 2021, 13:07 I've read all this thread and i still don't know what a codeplug is :?
A codeplug is a small file of radio configuration data, that is generated on a computer using
the customer provisioning software , then transferred over a cable (usually a serial cable) into the radio
for the purpose of configuring that radio to be used in a given radio system.
if you're more familiar with computers, think of it more like a windows .ini file or linux .conf file
Hope that helps
regards
BB
AMX97
Post by AMX97 »
Hi everyone ive got the CPS software the latest version from RadioTronics but when trying to read from the DP4400 i get a pop up saying #101005 not supported any ideas
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
Baofeng UV-9R
uniden ubc125xlt
Moonraker M10
Mototrbo2020
Has thanked: 23 times
Been thanked: 1 time
Post by Mototrbo2020 »
AMX97 wrote: 27 Oct 2021, 23:18 Hi everyone ive got the CPS software the latest version from RadioTronics but when trying to read from the DP4400 i get a pop up saying #101005 not supported any ideas
"codeplug version not supported" looks like you need a newer cps version.
Tittifer
Post by Tittifer »
bigbloke wrote: 27 Oct 2021, 16:50
Hope that helps
regards
BB
Thanks BB I think I get it now :)
siegfried
New User
New User
Post by siegfried »
HI!
I have the same problem with a motorola DP4400e VHF.
I have a codeplug, i can read from the radio it, but that's corrupt.
If I entry more as 2 channels the radio dont't work.
I hope the problem it's only the codeplug, but i'm not sure...
Can pls anyone send me a new sample codeplug for this radio?
THX
Siegfried
Mototrbo2020
siegfried wrote: 06 May 2022, 15:15 HI!
THX
Siegfried
Just recovery it in cps.
siegfried
New User
New User
Post by siegfried »
Mototrbo2020 wrote: 07 May 2022, 16:09
Hi, Thx for your's reply!
Unfortunately the recovery function does not work, it displays: error, can't find the recovery file for the connected device.
have anyone a sample codeplug pls?
I've searched it in the cps sample codeplug folder, but there are no sample codeplugs for dp4400e VHF.
Help!
Siegfried
Mototrbo2020
siegfried wrote: 07 May 2022, 16:56
Help!
Siegfried
In that case you will need to download a blank one that goes with your Firmware version and then recover it.
