RNLI Pager capcodes
Bycroft
Re: RNLI Pager capcodes
Post by Bycroft »
Hi,
As anyone managed to program a pager to receive the RNLI call outs, if so what type of pager would I need to get hold of and would I also need some software to re-program the pager.
Thanks.
Uniden Bearcat BCT-15X
Uniden Bearcat UBC-125XLT
Uniden Bearcat USC-230
Icom IC-R7000
Icom IC-R8500
Icom IC-736
Yaesu FT-7800E
AOR AR-8000
Baofeng BF-888
Baofeng UV-5RE Plus
Watson W-SDRX1 SDR Receiver
redman99
Post by redman99 »
Bycroft
Post by Bycroft »
Hi redman99,
Many thanks for your comments, I have the RLNI pager software on my computer but there can be up to an hours delay from when the call goes out on the RNLI crew pagers. I was in Seahouses last week, I had my scanner with me, the lifeboat was called out and the crew were talking to the Humber Coastguard. The message came on the computer some 40 minutes later, by this time the lifeboat was on it's way back to base.
I will keep my eye open for a Swissphone pager on the second hand market.
Once again thanks. Dave
Icom IC-R7000
Icom IC-R8500
Icom IC-736
Yaesu FT-7800E
AOR AR-8000
Baofeng BF-888
Baofeng UV-5RE Plus
redman99
Post by redman99 »
Do you need a pager or would something at home be ok ?
PDW is a pocsag/flex decode program for a pc via discrim tap
grafter
Has thanked: 7 times
Been thanked: 6 times
Post by grafter »
I haven't used PDW for a while but the older versions (the ones that supported FTP, upto 2.14 IIRC) also allowed SMTP mail delivery for filtered spots so you could have it sent as email to your phone or if you can find a suitable gateway have the resulting email sent as a text message. We used to use such a system and it was very quick, by triggering it off the initial page to the launching authority it would arrive via SMS before the crew pagers had gone off.
bigbloke
Been thanked: 3 times
Post by bigbloke »
In some areas I believe the RNLI pagers use channel 0 with neither flex nor pocsag
therefore little point in decoding these
regards
BB
DrumGeek
Post by DrumGeek »
Err can I just point out that Douglas, Peel, Port Erin, Port St Mary and Ramsey are in the Isle of Man, not Wales! :roll:
Mark (from the IOM!)
Uniden UBCD3600XLT| Uniden UBC780 XLT | Commtel COM215 | Realistic Pro-35 | Realtek RTL820 SDR x4 | SDR Play RSP2 | PiAware/Flightaware ADS-B Receiver | Yaesu FT-891 | Yaesu FT-817ND | Wouxun KG-UV8D | Tytera MD-380 | Anytone AT-D868UV
grafter
Post by grafter »
Best take it up with the RNLI, that was the station list copied from their website, grouped into their administrative regions prior to the changes in 2013.
everton72
Post by everton72 »
Do you no the radio freqs of the rnli at tall
clactononseaguy
Post by clactononseaguy »
Sorry to open an 'old' thread, but for info, I am using PDW on 153.337.500mhz you occasionally get RNLI pagers come through on there, as everything now goes through Capita, regardless of swissphone or not.
look out for Capcode 0600739 unknown location, 0040198 RNLI Portsmouth, 1001154 RNLI Newquay, 1001150 RNLI Cornwall
hope this helps anyone, also if anyone has any others to share, feel free.
pell3065
Post by pell3065 »
Has anyone managed to program a pager
pell3065
Post by pell3065 »
So what would West mersea cap code be please
tottenham773
Call Sign: 773
Post by tottenham773 »
Yes I have all capcode and pagers set up. As long as you live local you will get your local station and possible a flank one
tottenham773
Call Sign: 773
West mersa is 1021391. And 1021392 512 baud rate
tottenham773
Call Sign: 773
pell3065 wrote: 22 Feb 2021, 17:39 So what would West mersea cap code be please
