Hello all,
I have been listening to my local DMR cluster on an FM only radio just to gauge usage before investing in a DMR radio so far I haven't heard anything so my question is, is DMR used else where in the UK to any degree ? I am keen to use it through repeaters rather than a hotspot !
Thanks all.
Is there much DMR use near you ?
KILLERPARSNIP
- Has thanked: 71 times
- Been thanked: 6 times
- radiosification
Re: Is there much DMR use near you ?
DMR is used all over the place. It's probably the most widely used digital voice mode in the UK.
Which area are you in?
Octane Red
- Been thanked: 12 times
If you could let us know which repeaters, we can help you. But its all pretty vague what you are asking. The advice will vary depending on what repeaters you are listening to. For example, if the repeater is linked to Brandmeister, then we can point you to resources like Hoseline that will enable you to hear decoded audio, without yet having a radio. We can also steer you to resources such as DroidStar, VOX DMR or a plethora of other apps that will not only enable you to decode, but to transmit as well.KILLERPARSNIP wrote: 10 Sep 2026, 14:59 Hello all,
Thanks all.
But there are a number of networks out there, so until you give us some clues, we are a bit stuck in giving you some pointers that relate to what you are trying to do with your FM analogue radio.
KILLERPARSNIP
Hello all,
Thanks for the replies I've been listening for activity on the Salop and Boarders DMR cluster which include GB7DY,GB7WD,GB7KR,GB7BM as well as a couple of other repeaters which are at present not operational. I'm in South Shropshire on the Boarders of Worcestershire and can hear and use all the Analogue repeaters from these areas , I'm looking for a similar experience to using analogue repeaters and doing it my end at least via RF ( Radio Hams not Internet Hams) My biggest use will be mobile.
Many thanks all
Many thanks all
- radiosification
I'd recommend checking the coverage maps on ukrepeater.net to see if you're likely to be in range of any of those repeaters.
Alternatively just put all the frequencies in a scan list or a zone on your analogue radio and see if you pick up a buzzing/engine like sound on any of them. That would indicate you're in range.
KILLERPARSNIP
I have been listening to the local repeaters and only hear the occasional bit of data which I'm guessing is just the system talking to itself . I have now been told by a local ham it was at one point really active but soon died now having less activity than analogue VHF/UHF which around hear is near dead. I'm thinking after 30+ years it may be time to find another hobby !
- radiosification
If you can hear the repeater you can likely get in. You can get DMR radios very cheap these days, like £50 for a pretty decent one. Worth a try.
I find that activity generates activity on the radio - lots of people sit around scanning/listening but if you start talking to someone then they'll often join in.
Octane Red
Is that because the DMR repeaters appear to be connected via a localised network (Salop) rather than a global one like Brandmeister? I have little knowledge of the 'Salop' connectivity, but am aware that the other networks, BM, DVSPhoenix, etc are much larger.KILLERPARSNIP wrote: 21 Sep 2026, 11:14 I have now been told by a local ham it was at one point really active but soon died now having less activity than analogue VHF/UHF which around hear is near dead.
