I am about to up grade my mobile set up from a Baofeng UV5R mainly as I struggle to see the display whilst driving ( need glasses for close but then it blurs the distance ) and the old displays contrast is poor but also the memory amount is limited. Then I thought how about having a go at DMR at the same time ! I must admit I've never been keen on the idea but if I don't try it I cannot comment ! Worst case scenario is it only gets used on standard FM ! There are a number of interconnected repeaters in my area so why not. I am keen to use radio only rather than a hotspot but is DMR the best way to go of the digital voice modes ?
Thanks all
Brad
Which Digital voice mode is more common ?
KILLERPARSNIP
- Has thanked: 67 times
- Been thanked: 6 times
Octane Red
- Been thanked: 11 times
Re: Which Digital voice mode is more common ?
As on the several other threads you have started, please give us some clues as to what repeaters are near you. You sound like you are shooting in the dark.....
As well as several digital protocols - DMR, D-Star, Fusion, NXDN and what not, there are different networks that underpin some of these protocols. For example, with DMR, a repeater could be connected to Brandmeisiter, DV scotland / Phoenix, or a number of other servers. If you go and buy a radio that uses a protocol that is not used in your area, then its going to be very quiet.
Spill the beans on the repeaters you have in mind, and we can see what protocol / network they are using and will be better placed to advise you.
