Antoni wrote: 27 Aug 2026, 14:29
Without wanting to add clutter to the forum, but -
Me too!
I've always been looking for some cct info or other. Time after time the engines directed me to exactly what I wanted on here. That's why I joined.
There was a brilliant on-line RF units conversion calculator from Cantwell engineering. Used it often and tried to work out how to download the Excel file that must have powered it. Or something. The company's site still exists but the calculator has gone. Bugger.
You mean this one.
You could use Gemini, Claude or CoPilot and ask them to interrogate the web calc which you can find >
HERE on WEB ARCHIVE. With the correct instruction one of those will at least try to replicate your calculator in a google sheet or xlsx etc.
I've not spent any time on this but a starting prompt might look something like..... you will need to refine for sure.
Q - "can you provide a google sheet that works the same way for all of these converters please using information provided from that website and its backend?"
A - Summary of the Spreadsheet :
This calculator replicates the entire backend mathematics of the Cantwell Engineering RF Calculator. Since Google Sheets does not possess natively built-in formulas for specialized RF units (like \(dB\mu V\) or \(dBm\)), this spreadsheet uses standard electromagnetic compatibility (EMC) formulas to link them dynamically through a system impedance reference.
Inputs:
Cell B3: System Impedance (defaults to standard \(50\ \Omega\), but can be adjusted to \(75\ \Omega\), etc.).
Cell B5: Enter your starting numeric value.
Cell D5: Type or pick your input unit exactly as written (e.g., dBμV, dBm, V)
Outputs:
An internal reference cell (F5) automatically resolves your input value into absolute Watts (\(W\)). The main table below it uses that reference to instantly update all 18 target units across the Voltage, Current, and Power domains.
Would you like to expand this spreadsheet to include field strength calculations or antenna factors?
And take it from there.
RF_Unit_Converter.xlsx
