Dirt cheap led power supplies
Buick Mackane
Moderator
Moderator
Has thanked: 120 times
Been thanked: 93 times
Re: Dirt cheap led power supplies
Post by Buick Mackane »
Birdies heard on my HF radio running from a separate power supply with a short patch lead laid next to the cheap supply. But that was to be expected..
Buick Mackane
Moderator
Moderator
BTW The voltage range is 9.7 - 14.7 Which also effects the fan speed
Buick Mackane
Moderator
Moderator
I'd like to strip the PSU down to take a look at the quality workmanship :D But it doesn't look like it will come apart without wrecking it. It's happily ran for eight hours a day over the last two days with no issues, The radio is drawing 400ma on RX and a few amps on TX (17w) So unless something drastic happens i think i can wrap this thread up. It works.. But loading it up to its max capacity of 30 amps or hooking it to any of my expensive radios, Nope!!
Transwarp
Call Sign: Viper
Has thanked: 70 times
Been thanked: 101 times
Post by Transwarp »
At least you didnt blow y'sen up, and the birdies heard weren't angels 🪽💸 :thumbup:
