Dummy load
Hair Bear
Has thanked: 5 times
Been thanked: 5 times
Dummy load
Post by Hair Bear »
Hi,
I'm looking for help trying to fault find on a base installation.
The background is, a shop standard Grandstand base rig one end, and an Antron 99 on the other. Inbetween there are several sections of coax (I know, I know...). The reason for this is the original build dates back to 1987 and at that time the lead was one length of RG213. This was over time incorporated into the house, chased under floors and under plaster, through walls etc. been in place for years. At each end the antenna got moved and rearranged several times and as the main coax was pretty permanent lengths were added as necessary, and likewise indoors the rig got moved around with coax added and changed as required. None of this appeared to affect the operation of the system - good swr and always checked with the built in swr meter for consistency.
Now for some reason there's no rx or tx, the swr has hit the end stop and I cant work out why. I've been through all of it checking for opens and shorts but nothing obvious. A handset right beside the rig shows rx and tx both ways, but at 3' I'd hope so.
So, to my question...
If I had a dummy load and placed it on the antenna end of the coax, or any of the coax connections, would that give a zero or close to zero swr showing the cable to that point is ok?
One person in ten understands binary, the other one doesn't.
NightProwler
Has thanked: 58 times
Been thanked: 78 times
Re: Dummy load
Post by NightProwler »
A dummy load on the antenna end of the coax should show you an SWR of zero unless the coax is knackered somewhere.
Hair Bear
Re: Dummy load
Post by Hair Bear »
Thanks, that was what I was hoping for. Could you suggest a suitable spec for a dummy load to obtain for this purpose?
NightProwler
Re: Dummy load
As long as it's a 50ohm load and will handle what power you put into it then it will be fine. A 15 watt load will be ok as long as you don't put more than 15 watts into it. Make your own it's easy to do.
Hair Bear
Re: Dummy load
Post by Hair Bear »
What sort of components would be needed?
NightProwler
Re: Dummy load
I use one of these connected to an S0239 and bolted to a heat sink. Works perfectly up to 250 watts :thumbup:
https://www.ebay.co.uk/itm/178015434525 ... 7527740450
NightProwler
Re: Dummy load
Or one of these will do if you cant be bothered to make one...
https://www.ebay.co.uk/itm/267579680874 ... R7yXo_uFaA
Has thanked: 8 times
Been thanked: 30 times
Re: Dummy load
Post by ch25 »
NightProwler wrote: 23 Aug 2026, 17:02 A dummy load on the antenna end of the coax should show you an SWR of zero unless the coax is knackered somewhere.
SWR 0 does not exist in our world.
Hair Bear
Re: Dummy load
Post by Hair Bear »
Thanks, first time in more than 30 years it's failed me. I can normally find faults in mobiles quite quickly but this has stumped me.
I'll let you know how I get on, and what stupid simple thing I overlooked.
Cheers.
Buick Mackane
Moderator
Moderator
Has thanked: 120 times
Been thanked: 93 times
Re: Dummy load
Post by Buick Mackane »
ch25 wrote: 23 Aug 2026, 17:58
Aye and neither does the tooth fairy, But there are those who still worship him :lol: And i don't think I'd be ramming 250 watts into that tiny Chinese sweat shop resistor :wtf:
NightProwler
Re: Dummy load
I dont but it's been fine chucking 100 into it.
NightProwler
Re: Dummy load
Gordon Bennett, Ok then a low SWAAAAAR :thumbup:
Antoni
Call Sign: Triac
Has thanked: 20 times
Been thanked: 39 times
Re: Dummy load
Post by Antoni »
Those bolt-on power resistors do work. I bought three of the power attenuator versions rated at 100W (-10dB). They work as advertised with a good match/atten at 100W continuous and work at 450MHz (beyond that the terminations let them down a bit but bloody useful alll the same).
I'd get one of those 250W jobs but I have a professional AF 150W one. If you do any work on radios or feeders a dummy load of some sort is a must.
Слава Украине !
Re: Dummy load
Post by ch25 »
@OP put dummy load instead of antenna and measure. You'll know if coax is OK or not.
VNA would be better, because you can also measure coax loss.
