I've taken delivery of this nifty little HT and I am impressed with it, for the very low cost. It is 'unlocked', but I guess a factory reset would put it back to stock.
I'd like to use a PC to get to the extra features (well, one that I know of, least ways: Channel Name Tags), but the only cables that I can see are for the UV-5R. Does any know for sure if said USB cable is the same one for my GT-5R, please?
BAOFENG GT-5R
- rob42
- Has thanked: 61 times
- Been thanked: 24 times
BAOFENG GT-5R
QTH: Durham UK
Scanner: Uniden UBC125XLTC + Moonraker Skyscan Mobile Antenna
Software: Scan125 Control Program Suite
(http://www.nick-bailey.co.uk/scan125)
with my own scan125-frequency.log Monitor bolted on.
Transceiver: Baofeng GT-5R + NAGOYA NA-771
License Level: Pending
- Stronty
- Has thanked: 117 times
- Been thanked: 37 times
Re: BAOFENG GT-5R
Fairly confident a cable for a BAOFENG GT-3TP or 5TP like THIS ONE does the job. Whether its a genuine FTDI chip on the cable or not, I can't say but usually don't have any issues.
- rob42
Re: BAOFENG GT-5R
Thank you, Stronty.
Looking at the CHIRP website I see:
I'll get one of those and give it a go.
- GT-5 (use UV-82)
QTH: Durham UK
- rob42
Re: BAOFENG GT-5R
Very interesting and useful.
With thanks.
QTH: Durham UK
- rob42
Re: BAOFENG GT-5R
Just a quick update, for the sake of putting this to bed, so to speak: the programming cable that is linked here (thank you, Stronty) works just fine with my GT-5R. The CHIRP software is (for those who don't know) very easy to both install and use. Note: I am (for the most part) a Linux user, so if you use a different computer OS, you may have a different experience to one I've had. Also, it helps if you do in fact know how to operate a computer, rather than simply knowing how to push the keyboard buttons; I don't mean to come across as derogatory, it's just that I know that computers are, for many, simply treated as an appliance, which is fine, until it does not do what you expected it to do, then you're stuck.
I may try and use CHIRP on my Windows 10 based Netbook, but right now, I see no reason for doing that.
I noticed that when I d/loaded the .whl file, that it's date stamped 2026-08-07 02:21, so it's as fresh as the morning dew! Not sure what was updated, as there doesn't seem to be a change log, but I can tell you that the GT-5R is a listed device, so no need to 2nd guess about which profile to use.
QTH: Durham UK
- Stronty
Re: BAOFENG GT-5R
Thanks for updating the thread. As they use Redmine for development and bug tracking you get somewhat of a changelog HereI noticed that when I d/loaded the .whl file, that it's date stamped 2026-08-07 02:21, so it's as fresh as the morning dew! Not sure what was updated, as there doesn't seem to be a change log, but I can tell you that the GT-5R is a listed device, so no need to 2nd guess about which profile to use.
- rob42
Re: BAOFENG GT-5R
No worries; I like to be as complete as I can be, so that anyone who is following and has the same kind of questions as I've had, can get the full picture.
RE: Changlog. My bad; I should have looked a little harder, clearly.
I love that it's written in Python. As I'm a Python dev, I may even have a study of the code and see what I can learn.
Enjoy your weekend.
QTH: Durham UK
