Luiton LT-310SDR
Buick Mackane
Has thanked: 118 times
Been thanked: 80 times
Re: Luiton LT-310SDR
Post by Buick Mackane »
Yeah why they made the mic socket internal is beyond me
Buick Mackane
The Radio also has DSP Noise reduction and it sounds identical to those BHI DSP speakers. Watching the video above it seems to have the same volume issue as my CRT space. Which is even when the volume is on its lowest setting its still pretty loud. I wonder if it also has the same weak squelch as the CRT space. Either way its getting good reviews and is a hell of a bang for your buck. Tempted to sell my 706. I need one of these badboys :D
lambrettadave
Call Sign: TM455
Has thanked: 78 times
Been thanked: 61 times
Post by lambrettadave »
Buick Mackane wrote: 14 Jul 2026, 10:41 Yeah why they made the mic socket internal is beyond me
Way cheaper I guess
lambrettadave
Call Sign: TM455
At £105 it is good value but the shipping cost is a bit high and 7 watts on fm isn't great.
But it is very compact
Buick Mackane
lambrettadave wrote: 14 Jul 2026, 13:16 At £105 it is good value but the shipping cost is a bit high and 7 watts on fm isn't great.
Power wise its roundabout what most of the older gear was. You can always run a linear if you want more juice. I can conform they are tiny. Would fit in your pocket. Not that i own one but it looks almost identical to my CRT Space ''V'' version. Any smaller and they'll be posting them in an envelope. I expect British retailers will be getting them in soon. And i can see them being a big hit
Buick Mackane
ch25 wrote: 14 Jul 2026, 14:58
lambrettadave wrote: 14 Jul 2026, 08:09
Buick Mackane wrote: 14 Jul 2026, 07:05 Good old lemmy. No flies on you :) Be sure to let us know what you think of it once you've had time to try it out. Can the mic be unplugged or is it hardwired to the board ?
It's a telephone type plug in mic the same as the albrecht and crt 7900
LAN Rj45 actually. Phone is RJ11
First test today.
Be sure to post back with your opinion :thumbup:
lambrettadave
Call Sign: TM455
Buick Mackane wrote: 14 Jul 2026, 15:55
I have a space U and a crt millennium and a team minicom too.
The minicom is slightly narrower than the others as it fits in my ashtray in the car the others are slightly too wide
Buick Mackane
I wonder how many of these things would fit inside a HaM Jumbo ?
lambrettadave
Call Sign: TM455
Buick Mackane wrote: 14 Jul 2026, 17:18 I wonder how many of these things would fit inside a HaM Jumbo ?
One would look lost on the top of a jumbo
Stronty
Has thanked: 61 times
Been thanked: 20 times
Post by Stronty »
For those buying and you don't get a programming lead. You need a RJ12 to make your own lead up.
Also. with the programming software you can adjust the volume levels across all modes. That should take care of your volume issue, wonder if there is something similar for your CRT @Buick?
Credit to Simon the Wizard, Shadetree Mechanic & PapaSierra for the pics and information.
Here's the software:
Luiton LT-310 SDR
Here's the programming note:
note_programming_software.docx
Can't help but love an Adams.
Stronty
Post by Stronty »
Software view.
Moonraker have one . No idea of Board revision ATLAS 10M Mini
Also worth noting if that some variants come with a standard Mic Socket. :o
Buick Mackane
Stronty wrote: 14 Jul 2026, 18:49
Possibly Dougie. My radio although it can be programmed via a PC its pretty simple to program via the front panel buttons. £17 for a PC cable. Not on my shift. I could make one if i could find the schematic. But as i say not needed in the case of the CRT Space radios. Good info BTW :thumbup:
