Signal Dropout
A place for new members to say hello and to introduce yourself.
If you're not sure where to post, try here!
rob42
Has thanked: 25 times
Been thanked: 7 times
Signal Dropout
Post by rob42 »
Could someone tell me why it is that I get a pattern of:
RxRx _ RxRx _ RxRx _ RxRx _ etc, etc
... where Rx is a nice strong (or even a not so strong) signal of 2secs, and _ is a 500ms drop out? I'm guessing at 500ms, but it's certainly less than 1 second.
This seems to be FM related, and does not occur when I'm listening to Aircraft (the AM signal).
It's kind of annoying more than anything else. And it's not that I like to snoop on what others are saying; in fact when I hear chatter of an evening that's clearly between guys that know one another, (on 2m, for the most part), I hit the Temp L/O, and continue my scanning. Signal and equipment checks are more interesting to me, and I get some idea about where these guys are and the Tx/Rx distance.
Edit to add: it's not Squelch issue, btw :)
I also get this consistent pattern when there's just a carrier wave, as with 914.6000 MHz: hisss _ hissss _ hisss _ in 2sec, 500ms intervals.
[was not sure where to post this, so here it is]
Scanner: Uniden UBC125XLTC
Antenna: Moonraker Skyscan Mobile
http://www.nick-bailey.co.uk/scan125
Has thanked: 7 times
Been thanked: 21 times
Re: Signal Dropout
Post by ch25 »
Nearby transmitter blanking your RX?
rob42
Re: Signal Dropout
Post by rob42 »
I think not, becasue when I get out and about in my car (one of the reasons that I have a set-up that is portable) I get the same experience, regardless of where I park up. Also, would I not see a spike, rather than a drop out?
What I'm unsure about is if this is what I can expect from my gear, or if the Scanner has a fault, and as such should be replaced.
rob42
Re: Signal Dropout
Post by rob42 »
Guys; I've sussed it!
What I'm experiencing is the Close Call Interrupt:
  • Close Call Pri (Priority) - checks for Close Call hits every 2 seconds, even during transmissions.
... the 2sec duration should have been the giveaway for me.
Issue resolved. :)
Buick Mackane
Moderator
Moderator
Has thanked: 112 times
Been thanked: 68 times
Re: Signal Dropout
Post by Buick Mackane »
Those wind turbines can cause issues on high frequencies
Buick Mackane
Moderator
Moderator
Re: Signal Dropout
rob42 wrote: 17 Jun 2026, 15:05 Guys; I've sussed it!
Issue resolved. :)
Aha. Never thought of that :D
rob42
Re: Signal Dropout
Post by rob42 »
Buick Mackane wrote: 17 Jun 2026, 16:04 Those wind turbines can cause issues on high frequencies
Interesting; I'll keep that in mind jic I get any other anomalies.
Transwarp
Call Sign: Viper
Has thanked: 59 times
Been thanked: 83 times
Re: Signal Dropout
Post by Transwarp »
Hey, this is the new member thread 🤔
Buick Mackane
Moderator
Moderator
Re: Signal Dropout
Transwarp wrote: 18 Jun 2026, 16:15 Hey, this is the new member thread 🤔
Yea Trans. They are a newbie. And if newbies aren't sure which section to post in they're encouraged to post here
Transwarp
Call Sign: Viper
Re: Signal Dropout
Post by Transwarp »
Fair enough.
