MORSE on 70cm
rob42
Has thanked: 11 times
Been thanked: 6 times
MORSE on 70cm
Post by rob42 »
I'm getting
Code: Select all
GB WTS
... on 433.1750 MHz
Anyone know what that is?
It's kinda intermittent, so if you want to hear it, you'll need to be patient. I've tried to pin down any pattern to the TX times, but there's none that I can determine, save for it seems to repeat apx 10 to 15 minutes between transmissions (e.g: 10:07 then 10:12 and 15:00 then 15:16, but this does vary, from day to day).
Scanner: Uniden UBC125XLTC
Antenna: Moonraker Skyscan Mobile
Software: Scan125 Control Program Suite
http://www.nick-bailey.co.uk/scan125
milly
Call Sign: redacted
Been thanked: 8 times
Re: MORSE on 70cm
Post by milly »
Probably an error in your CW as it will almost certainly be:
GB3TS (--. -... ...-- - ...)
The repeater isn't very far from you
rob42
Re: MORSE on 70cm
Post by rob42 »
Thank you, milly.
It's real hard for me to catch. I've also heard 'voice' on that freq, which adds to the challenge. :geek:
milly
Call Sign: redacted
Re: MORSE on 70cm
Post by milly »
You know it's in part of the spectrum allocated to radio amateurs. As Good Buddies Limited want people to use specific bits of that for specific things you can expect it to be a repeater output.
Clues like the signal strength being fairly consistent, voice as well as a CW ident makes it easier?
