Does anyone know which Airfield, in the North East, uses 130.200 MHz ?
The only ones I can find are Chivenor and Cottesmore, but I can't see that I'd be able to get a reception from those, given the distance.
130.200 MHz
- rob42
- Has thanked: 54 times
- Been thanked: 22 times
130.200 MHz
QTH: Durham UK
Scanner: Uniden UBC125XLTC + Moonraker Skyscan Mobile Antenna
(http://www.nick-bailey.co.uk/scan125)
with my own scan125-frequency.log Monitor bolted on.
Transceiver: Baofeng GT-5R + NAGOYA NA-771
License Level: Pending
Ripshod
- Call Sign: 26TM255
- Has thanked: 34 times
- Been thanked: 13 times
Re: 120.30 MHz
130.200 LBA Tower
If you're picking that up worth listening on
118.030 LBA ATIS
134.580 LBA Approach
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
121.800 LBA Deliveries
131.680 LBA Ops
125.380 LBA Director
455.4875 FM - Local repeater for ground crew
** Edited to include director and correct some frequencies
118.030 LBA ATIS
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
131.680 LBA Ops
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
- rob42
Re: 130.200 MHz
@Ripshod: Ty. I'll pop those into my AT Bank, and see what comes back.
QTH: Durham UK
- rob42
Re: 130.200 MHz
@Ripshod: Reporting back that I have RT on 131.550
Is that part of the LBA also?
QTH: Durham UK
- rob42
Re: 130.200 MHz
@Ripshod: Ah! There we go. Your updated Freq of 130.200 now ties in with my topic title. Thank you very much; it's far more likely that I'd be getting RT from LBA, given that it's much closer to me.
QTH: Durham UK
Mototrbo2020
- Has thanked: 30 times
- Been thanked: 4 times
Re: 130.200 MHz
LBA tower is 120.3
Ripshod wrote: 31 May 2026, 05:38 130.200 LBA Tower
118.030 LBA ATIS
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
131.680 LBA Ops
- rob42
Re: 130.200 MHz
Okay, ty for that. Now I'm a little confused, but then again, the chatter that I heard yesterday on 130.200 did not sound like the typical chatter that one hears from ATC. It sounded more like ground crew, tbh: there was talk about refueling and engine starting, etc.
QTH: Durham UK
Ripshod
Re: 130.200 MHz
You are, indeed, correct.Mototrbo2020 wrote: 31 May 2026, 09:42 LBA tower is 120.3
118.030 LBA ATIS
131.550 Swissport
131.480 LBA Jet2
121.600 LBA Fire
134.580 LBA RADAR
131.680 LBA Ops
I blame number dislexia. Seems I've misled the op somewhat.
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
- rob42
Re: 130.200 MHz
Not a worry; mistakes happen all the time. In fact, it's a quite refreshing to find someone who admits to a error; in this day and age, that has become a rare thing indeed.
QTH: Durham UK
