Shopwatch and CCTV:
456.600MHz DMR CC:0 TS:1 TG:None
Enforcement(?):
462.100MHz DMR CC:0 TS:1 TG:None
Castleford Shopwatch
Ripshod
- Call Sign: 26TM255
- Has thanked: 26 times
- Been thanked: 6 times
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
Ripshod
Re: Castleford Shopwatch
They're leasing simplex radios from Apex, Listen on 456.600 you'll hear both sides of the conversations. 462.100 is only used when the enforcement team are in town.
Check out radio reference - these radios are DMR simplex.
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
aspect1968
- Call Sign: G7POT
Thanks for these. I was hoping to find them. Is there a shopwatch for Potefract or Wakefield?
I have Hull Beverley Scarb and Brid if you need them. York too I think
Ripshod
Apex have 440.1375 and 425.6375 (both DMR) listed for Wakefield, and 453.5 and 460.0 (both DMR) for Ponte.
I'm a little far away to confirm these.
https://radioreferenceuk.co.uk/frequenc ... d&range=10
26TM255
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
IO93HR
Anytone Ares II
Anytone Q6 Pro
Rotel RVC-240
TYT MD-UV390 Plus
Antron 99
aspect1968
- Call Sign: G7POT
andy2010
Iv heard Wakefield on 425.6375 but not sure what exactly it is as Shopwatch used to be 453.700 before heading to encrypted. Ponti last I heard was still encrypted.
