If you bought it from a shop why not drop them a email stating the facts.
I doubt they will exchange it but at least you whether it's right or wrong
- lambrettadave
- Call Sign: TM455
- Has thanked: 36 times
- Been thanked: 50 times
scanhermit
- Has thanked: 35 times
- Been thanked: 56 times
I got it from Thunderpole over a year ago. I may email them - I'm not bothered about a refund but they might want to know for their own good.
It's possible that the wrong tactical got slipped in the wrong packaging at the factory and it's just me that's ended up with it, or it may have been, and may still be, a problem.
Mind, I did submit a review that, using actual test results to other breakers and my scanner at home, described it as inferior to the stock antenna. They never published it so I don't know if they welcome any constructive criticism.
scanhermit
Before I shot my mouth off, I decided to retest. This time I tied a counterpoise to the BNC connector and held the antenna by the connector. I did it outside to lessen the chance of anything electronic skewing the result. I tested the other antennas too. Results:
Antenna. Freq. SWR. Ohms
Stock antenna: 26.9 1.15 54
Abree rub duck: 27.7 1.23 40
Telescopic: 27.0 1.23 40
Tactical: 32.5. 1.03 51
The tactical was 8.5:1 SWR on 27.7mhz. It's not as drastic as I thought yesterday but still way outside 11m usage, with the caveat that the test was not on even a makeshift handheld substitute. However, I think the results for the other antennas suggest that it's a reasonably accurate test.
- lambrettadave
- Call Sign: TM455
If you are getting right results with other twigs then I would be only using the tactical one for decoration or selling it
scanhermit
I've cut it open to see how it's made
I also sent an email to Thunderpole sales. I was even-handed, saying that there are those who do report an improvement over the stock antenna but there are enough reports to the contrary to question the manufacturing consistency. One chap who Nano'd it also reported resonance in the 30mhz range.
We'll see if they respond.
- lambrettadave
- Call Sign: TM455
Good, it's pointless selling the wrong antenna especially if it's been made for some other set
scanhermit
I would hope that they'd batch test the tacticals. Anyway, I'll see if I hear from them.
- lambrettadave
- Call Sign: TM455
To think I nearly bought one.
Have to be truthful I have bought very little from thunderpole, year's ago I bought a skiptech hs2000 handheld that had legally been changed to a 40 FM cept handheld and recently I got a case for the intek H520 handheld but that is it
