Yaesu FT857D strange behaviour
2E0BSL
Call Sign: 2E0BSL
Has thanked: 1 time
Been thanked: 4 times
Post by 2E0BSL »
My FT857D has been intermittently resetting on power up. Some years ago on a field trip, it had it's polarity briefly reversed. I suspected a partially damaged reverse polarity diode but cannot find one on the circuit diagram. Any ideas? Thanks in advance.
MrWeetabix
Call Sign: 26TM175
Has thanked: 9 times
Been thanked: 5 times
Re: Yaesu FT857D strange behaviour
Post by MrWeetabix »
does it work normally other than it resets on power up? Kinda sounds like a memory battery if so. I am basing that on no hard facts by the way. haha
2E0BSL
Call Sign: 2E0BSL
Has thanked: 1 time
Post by 2E0BSL »
Thanks for the reply. After swapping out my PSU (Palstar PS30m) I found a known problem with the PSU. It doesn't like FT857D when powering up and goes into oscillation, causing problems with other radios also. For anyone interested
https://www.qsl.net/pa3fqh/ep920/ep920.html
