Legal Handsets Augmentation
scanhermit
Has thanked: 18 times
Been thanked: 47 times
Post by scanhermit »
I'm not treading new ground here but I thought I'd share what has worked for me to extend the range of a particular legal radio (Retevis H777D). I've not gone into it with a screwdriver but have just experimented with a counterpoise and an antenna extension. The counterpoise results were mixed, clearly better in some locations than others. The counterpoise was simply taped to the negative charging terminal.
By far more generally effective has been attaching a 1/4 wave length steel rod to the side of the antenna casing with tie wraps. From a test point nearly 2 miles away back to the QTH the antenna extension resulted in readability rising from R2-3 to R4-5. I also made contacts over 23, 24 and 30 miles. The first was over a path I wouldn't have expected the H777D to get over. The other two were over open paths to high points at Queensbury and Holme Moss but at higher signal and readability levels than I'd expect with the radio.
I did try fitting a half wave rod but it moved too much while the 1/4 wave stays in place. Anyway, for those with limited means and a short antenna this is an almost cost-free way to extend their range.
