What Ham Radio Stuff did you buy today?
DX-Digger
Call Sign: TM205
Has thanked: 43 times
Been thanked: 24 times
Re: What Ham Radio Stuff did you buy today?
Post by DX-Digger »
So with my half size G5RV having seen better days, the feed has detached on one leg.
So I have just ordered a ZS6BKW which is a more optimised version.
When it arrives and gets put up, we will see how it performs.
Im hoping it will out perform the 5RV time will tell I guess
:thumbup:
PaulBritInHolland
Call Sign: M7FKF
Been thanked: 2 times
Post by PaulBritInHolland »
Strawberry wrote: 05 May 2025, 18:06 I've found another video on the cheap Ali Express portable antenna.
https://www.youtube.com/watch?v=TI-VLHjhIe4
Also now had notification that it has been dispatched so should be here in a week or so, maybe less.
I reckon I'll crimp some rings onto the counterpoise radials and pin them out with tent pegs.
I have three radios I could use, a little four band Xiegu G1M, an FT-817 or the MChf, I'm pretty excited about this one. :D
I have this antenna - I find it works very well. It is simple, but does the job. There is supposed to be an extension coil for 40m as well.
falbo
Post by falbo »
Yaesu FT 710 with the matching speaker.
68TM006 PAUL.ARDGLASS CO DOWN N.IRELAND.
Wriggly Ron
Call Sign: M7XDN
Been thanked: 3 times
Post by Wriggly Ron »
I bought a Pixie kit. Or is it a Super Pixie? Took an age to arrive from wherever it was in the UK. Built it last night and it seems to be receiving. Any tips for an antenna are welcome, appropriate for a small terraced house....
Now just got to get my code up to scratch. Been using lcwo.net and have been progressing, but slowly. Took a year out, but that applied to all radio really.
Also have built a boomerang clone. That's gone pretty well. Built a prototype, now will make it properly. Uses a tank whip, some tentpoles, some bell wire, shrink wrap and some stud mounts. Found that by changing the length of wire in the ground radial I influenced where it tuned in. A quarterwave length tuned in about 29MHz, when I fitted a 5/8th length it shifted to 26Mhz. By using something in between I managed to tune it to 28Mhz, where I wanted it. I'll post some more details about it if anyone is interested. I doubt I saved much money over a £50 boomerang but I did learn a lot about antennas. Also about making home-made Firestiks...
CookieRaider
Call Sign: 26TM506
Has thanked: 17 times
Been thanked: 14 times
Post by CookieRaider »
3 Weeks signed of work from an operation and now the boredom has set in {bnghd}
On a whim i purchased an Anytone Ares to use on 10m more for nostalgia i guess as the FTDX10 is more than capable :lol: well that went back as the 'unable to test as i have no aerial' proved to be a faulty ext speaker socket (no audio from int speaker) , listed as 'used' not parts only, no doubt that will end up being sold again as 'un tested'
Absolutely no use for a manual tuner, still not sure why i bought it but it looks nice on the shelf :lol:
Wanted another of these, have one on an Icom 2730e in combo with a Marantz condenser mic, the new one is on the FTDX10 with a 636L
Winner of the coveted 'In Before The Lock' competition 07 Jan 2013
Winner of the coveted 'In Before The Lock' competition 24 June 2013
inaugural champion of the coveted "Putting sex before trivial internet games" award November 2013
CookieRaider
Call Sign: 26TM506
Finally got around to sorting something half decent for 10m/11m/12m for what i use it for the height is perfectly adequate and the neighbours (and wife) didn't throw a fit as it replaced a Sigma SE HF-360 that was on that poll ..... just told the wife it was the same size, some women will believe anything :lolno:
and finally a President McKinley for 11m couldn't find a SH EU model so had to get the export and un-mod it , another 2 weeks off work, not sure the bank account can take much more of this
DX-Digger
Call Sign: TM205
Post by DX-Digger »
So I picked up a BHI speaker, Image
And a PK232 TNC unit for Amtor RTTY Morse Packet Fax etc.
:D :thumbup:
CookieRaider
Call Sign: 26TM506
A TS450 thats going back tomorrow, the seller neglected to tell me the RIT/IF shift had been rammed on then glued in place so hard the cresent spline was pushing out , both splines were fused together with the glue which was also on the outside rotary , I need to stop buying crap late at night 😔
DX-Digger
Call Sign: TM205
Post by DX-Digger »
CookieRaider wrote: 11 Mar 2026, 22:31 A TS450 thats going back tomorrow, the seller neglected to tell me the RIT/IF shift had been rammed on then glued in place so hard the cresent spline was pushing out , both splines were fused together with the glue which was also on the outside rotary , I need to stop buying crap late at night 😔
There seems to be a trend of undisclosed faults on ham gear recently. When the pk232 arrived the threshold knob was seized solid. no mention in the advert. I managed to unseize it using Premixslip by Ruhof That stuff is awesome.
Anyway I hope you manage to work it out.
CookieRaider
Call Sign: 26TM506
Well I'll go to the foot of our stairs.
I swapped my TS2000X (with 23cm) serial was the last 2 months of production for an FTDX10 and hated it, just wasn't me, this was 2 or 3 months ago, yesterday I saw the guy up in Scotland trying to swap the TS for a FTDX10...... the TS is coming home :lol:
CookieRaider
Call Sign: 26TM506
A Kenwood TS 570D to replace the dog of a 450 that went back, and one of these ...
Gave up unscrewing coax plugs every time a swapped out a set
CookieRaider
Call Sign: 26TM506
I only went in for a triplexer :?
CookieRaider
Call Sign: 26TM506
Another eBay 'sold as seen' this one is fully working with a Racal9904m
CookieRaider
Call Sign: 26TM506
Wanted one for a while now but not seen a clean one (at a sensible price) with at least 2 couplers, found one with 3 couplers for £100
Needed a minor repair/mod .... very happy :D
Boxed Kenwood SW-200
CookieRaider
Call Sign: 26TM506
Purchased from a dealer, not because i need one but it looked nice ;) added the led but in hindsight a warm white might have been better
Heil Pro-set plus, audio on the 991a with the HC-4 is amazing, heard someone else on one and took the plunge
For the SS, really couldn't justify the prices of a teardrop so i bought a Red Devil from the states for a fairly decent price, once i sorted the crappy ptt switch out and lost the red it (to me) looks a bit better :lol: ..... oh and the build quality on these new ones is shocking :?
So far the audio reports are good
