Afternoon all
I recently wrote a tool that converts the "Frequency.xml" file used by SDR-Sharp to the JSON file used by SDR++.
I wrote it for myself to convert my frequencies and I've decided to make it available in case anyone wants to use it.
http://tesko.magicpack.net/sdr.html
Enjoy
SDR-Sharp to SDR++ Freq Converter
Re: SDR-Sharp to SDR++ Freq Converter
Done a little update and the tool will now convert back the other way - from SDR++ to SDR-Sharp.
This means you can keep the file/s in sync across the 2 apps.
Just a little bump to say I've released a new version .
Only a small change - if the target file exists (your SDR++ json or frequencies.xml file) it won't just blindly overwrite it now, it will rename it including the date and time. Essentially it's backing it up
Little bump to say we're now up to v1.3.2
Couple of bugs and niggles have been sorted.
And another little bump to v1.3.3 now.
Minor bug relating to quote marks when converting to SDR++ JSON.
