Manchester Airport TIII systems
milly
Call Sign: redacted
Been thanked: 3 times
Post by milly »
Anyone set up DSD+ for monitoring the Manchester Airport TIII network? Likewise for the Affini Technology one (though from distant memory that one was single site and relatively simple).
Have a layover for a few hours next week and a headstart on the config files would be appreciated (PM fine if info needs to be less 'public')
CrazyRach82
Re: Manchester Airport TIII systems
Post by CrazyRach82 »
Did you ever manage to get the files for this?
moj
Has thanked: 1 time
Been thanked: 2 times
Post by moj »
sadly its not as easy as that Milly , never heard anything on the affini tech either in years but tetra was supposed to be in use on there also the tier 3 is a ras trunking system so constantly jumps around mate so you can't follow a conversation .
milly
Call Sign: redacted
Post by milly »
mmm...was two years when I asked. I did get to spend a bit of time searching but found only encrypted comms on the Affini network. The airport network was all in the clear with comms from buses, rangers, lost sheep, clenaers and the like.
moj
Has thanked: 1 time
Post by moj »
well i've never heard lost sheep or rangers so far :p , but yeah everything else you mentioned is correct and annoyingly fire jumped on there aswell off there original channel that they used to use !!
CrazyRach82
I’ve heard transmissions on a couple of the affini channels. It’s very few and far between, but at some points it’s active for a short while.
moj
Has thanked: 1 time
Post by moj »
so you are actually hearing tetra then on the affini frequencys ?
CrazyRach82
It’s not tetra, it’s tier iii
moj
Has thanked: 1 time
Post by moj »
no Rach the Affini tech i'm mentioning were mostly heard on 454 mhz , the tier 3 dmr your talking about is spread over the 440 and 445 mhz .
moj
Has thanked: 1 time
Post by moj »
and just looking now all the tetra licences have vanished off there now hmmmm ?
