hi i am new here but needs some help i just got off ebay a motorola dp4600e and a dp4401e was told no passwords was on them but when pluged in to software showing thay have passwords on dose any one have any code plugs so i can get to use the radios for work thanks
perry1978 wrote: 23 Mar 2023, 15:29
Hi,
please help me find the code pluging for a Motorola dp4600e H56RDQ9VA1AN.
I spent all day but still couldn't find it. I bought dp4600e on the website with a password.
When I click recover in the CPS, I am asked to enter Key Alias and Key Value.
Thanks, Dmytro.
smelyanin wrote: 18 Feb 2024, 18:14
Hi,
Thanks, Dmytro.
Sounds like it has TLS-PSK, your not going to get around that with basic skills unfortunately.
Thank you, I called the Motorola service center, but without documents for the radio station, I will not be able to remove the key. Therefore, I have gained experience now Sorry, I still have 1 more question, can I remove the 4-digit password when turning on the radio without TLS-PSK? Perhaps I could use this radio to test batteries.
smelyanin wrote: 19 Feb 2024, 11:55
Hi, im in the same situation as most, I have 10x 4401 vhf radios and need a blank/usable codeplug as the sample in all versions of CPS I have dosent have the VHF version. Im well versed in programming Mototrbo equipment just dont have a NZ/Aus codeplug.
Basically I bought these radios as part of business liquidation and the original programer ( unkown ) has set them up via RM so there is no way with out installing a blank / different Codeplug across all these radios I can access anything let alone read them them on any version of CPS ( I have most versions and generations ), as you would assume all the dealers in NZ have been as helpful as you expect and basically think im robbing a bank. All my other units are DP2400e's and these radios were going to be the upgrade.
Any assistance would be appreciated.
P/s before you ask I dont need any of the data off these radios and am happy to wipe them.
Hi there try 2.0 cps and not working with motorola dp4400
Keep say
Codeplug version not supported. Please refer to the readme file of the application for supported codeplug versions
