Deaf radio
Agent 48
Has thanked: 6 times
Been thanked: 4 times
Deaf radio
Post by Agent 48 »
I have a couple of deaf radios in need of realignment. They were programmed to 2 meters but the receivers need adjusting for the frequency. I don't have the right test equipment to tune them up and I really don't want to spend hundreds on equipment that I'll rarely use.
I need to build something simple that gives a weak signal on 145MHz so that I can tune the receiver to the loudest sound.
What would be the best way to align the receiver?
Has thanked: 7 times
Been thanked: 20 times
Re: Deaf radio
Post by ch25 »
Use another radio. TX to dummy load. Move it away to get desired signal level.
Agent 48
Re: Deaf radio
Post by Agent 48 »
Cheers I'll do that. I never thought of that.
DX-Digger
Call Sign: TM205
Has thanked: 41 times
Been thanked: 24 times
Re: Deaf radio
Post by DX-Digger »
friend of mine used to put a handheld on low power and a rubber band around the ptt and put it inside his fridge.
worked a treat.
