Motorola Codeplug wanted
siegfried
New User
New User
Re: Motorola Codeplug wanted
Post by siegfried »
Mototrbo2020 wrote: 08 May 2022, 11:07
In that case you will need to download a blank one that goes with your Firmware version and then recover it.
Yes, has anyone that file?
Am I the only one that the radio does not allow to save more than 2 channels?
Thx
Siegfried
Mototrbo2020
Has thanked: 23 times
Been thanked: 1 time
Post by Mototrbo2020 »
siegfried wrote: 08 May 2022, 11:39
Thx
Siegfried
Should be able to download it from the Motorola portal. Do you mean only 2 zones? You should have 16chs per zone and 2 zones.
perry1978
Post by perry1978 »
hi i am new here but needs some help i just got off ebay a motorola dp4600e and a dp4401e was told no passwords was on them but when pluged in to software showing thay have passwords on dose any one have any code plugs so i can get to use the radios for work thanks
Mototrbo2020
perry1978 wrote: 23 Mar 2023, 15:29 hi i am new here but needs some help i just got off ebay a motorola dp4600e and a dp4401e was told no passwords was on them but when pluged in to software showing thay have passwords on dose any one have any code plugs so i can get to use the radios for work thanks
Just recover them in cps.
sorel21ro
Post by sorel21ro »
hello can i have a codeplug for a dp4400e model MDH56RDC9VA1AN without a password thanks
smelyanin
Post by smelyanin »
Hi,
please help me find the code pluging for a Motorola dp4600e H56RDQ9VA1AN.
I spent all day but still couldn't find it. I bought dp4600e on the website with a password.
When I click recover in the CPS, I am asked to enter Key Alias and Key Value.
Thanks, Dmytro.
Mototrbo2020
smelyanin wrote: 18 Feb 2024, 18:14 Hi,
Thanks, Dmytro.
Sounds like it has TLS-PSK, your not going to get around that with basic skills unfortunately.
smelyanin
Post by smelyanin »
Thank you, I called the Motorola service center, but without documents for the radio station, I will not be able to remove the key. Therefore, I have gained experience now :) Sorry, I still have 1 more question, can I remove the 4-digit password when turning on the radio without TLS-PSK? Perhaps I could use this radio to test batteries. :roll:
Mototrbo2020
smelyanin wrote: 19 Feb 2024, 11:55 Thank you, I called the Motorola service center, but without documents for the radio station, I will not be able to remove the key. Therefore, I have gained experience now :) Sorry, I still have 1 more question, can I remove the 4-digit password when turning on the radio without TLS-PSK? Perhaps I could use this radio to test batteries. :roll:
No I don't believe it will let you do anything.
sabordab
Post by sabordab »
you can purchase one online
pawel40pawel40
Post by pawel40pawel40 »
Witam,
Bardzo proszę o pomoc w poszukiwaniu czystego codeplug do Motoroli DP w wersji UHF - DP 2400e, DP2600, DP2600e.
Bardzo proszę o pomoc.
Hello,
I am asking for help in finding a clean codeplug for Motorola DP in the UHF version - DP 2400e, DP2600, DP2600e.
Please help.
Reason: Translation
A10shon
Post by A10shon »
Hi, im in the same situation as most, I have 10x 4401 vhf radios and need a blank/usable codeplug as the sample in all versions of CPS I have dosent have the VHF version. Im well versed in programming Mototrbo equipment just dont have a NZ/Aus codeplug.
Basically I bought these radios as part of business liquidation and the original programer ( unkown ) has set them up via RM so there is no way with out installing a blank / different Codeplug across all these radios I can access anything let alone read them them on any version of CPS ( I have most versions and generations ), as you would assume all the dealers in NZ have been as helpful as you expect and basically think im robbing a bank. All my other units are DP2400e's and these radios were going to be the upgrade.
Any assistance would be appreciated.
P/s before you ask I dont need any of the data off these radios and am happy to wipe them.
Happy pay for a working codeplug
G7VNQ
Call Sign: G7VNQ
Post by G7VNQ »
I'm also looking for a blank to start my DP4400e, or one that I can write over.
UK Amateur use.
Thanks.
Kev S
Davebr30
Post by Davebr30 »
Hi there try 2.0 cps and not working with motorola dp4400
Keep say
Codeplug version not supported. Please refer to the readme file of the application for supported codeplug versions
