Great Yarmouth Shopwatch
Scanning radio frequencies for East Anglia
deadite66
Call Sign: 26TM7373
Been thanked: 1 time
Post by deadite66 »
Noticed this week they have turned their tx power down, used to pick up easily with a handheld scanner, now only receiving on my Airspy/Discone.
166.1375
SDRPlay RSP1A + CrossCountryWireless Loop
Icom IC7410 + thunderpole boomerang
Retevis RT90 (opengd77) + Diamond x50
Yupiteru MVT-9000MKII, Baofeng DM-1801 (with opengd77)
Bogget
Re: Great Yarmouth Shopwatch
Post by Bogget »
unliky to have turned power down as users dont have access to power settings in normal use as they would most likley turn them up ...
either they developed a fault in the coax or arial or the arial has been re-sited for one reason or another........Or something has been errected between them and you scaffolding maybe or new building going up.
draw a line on a map and check it out.
Bogget
Amateur does not have a CH its pronounced "am-a-tore" NOT am-a-chure !
AdrianNR30
Post by AdrianNR30 »
I'm only a mile or so from the town centre and struggling to receive them now on handheld, wonder if it's something to do with the development of the Market Place? The "Pubwatch" transmitter which I believe is situated further away from me on the sea front came up briefly (166.8875) and sounded just as strong as normal.
deadite66
Call Sign: 26TM7373
Post by deadite66 »
Their power has been back to normal for the last few weeks, also 165.1375 using DMR is getting used more, they could be starting to transition.
leonsimmons5
New User
New User
Has thanked: 1 time
Post by leonsimmons5 »
deadite66 wrote: 12 Jun 2021, 07:30 Their power has been back to normal for the last few weeks, also 165.1375 using DMR is getting used more, they could be starting to transition.
Im often listening to this, Plugged my anytone 578 into PC and ran it via zello. I have noticed they are having issues with people in the town listening and following them the past 6 months. Which is likely to force them to switch to network/poc radio soon enough :roll: I do have a whatsapp group where listeners in the area post certain things happening, lifeboat launches (i send as soon as tasking page is sent out then follow up with launch). something you or others may be interest in just pop me a PM and will guide you in the right direction.
