Dummy Load High SWR?
Dave C
Call Sign: 27PL259
Post by Dave C »
Hi All,
I've just knocked together a 50 Ohm Dummy Load with 3 x 150 Ohm resistors in parallel as per my pic, it measures 49.8 Ohm so pretty much smack on tolerance. The patch lead that I used is about 12" long (30 cms), but when I key up the mic the SWR reads at about 1:7, does anyone have any suggestion where I can go from here to get it down please? Also tried and alternative patch lead to rule out that {bnghd}
Thanks in advance..
Dave
Life is like a box of chocolates.... Usually empty when I get there.... :crazy:
Rigs: Major M588 AM FM SSB (Std), President Grant II Premium (Std), Midland Alan 78 Plus (Std), Lowe TX 40 (Std).
Twigs: Antron 99 (Std), K40 Mag, Firestick 4', Cherokee Dial A Match 4', Sirio 1000 PL Mag.
Has thanked: 7 times
Been thanked: 25 times
Re: Dummy Load High SWR?
Post by ch25 »
I can't see photos, but aren't they wirewound?
wa10
Post by wa10 »
as above, are they inductive wirewound resistors?, or is the patch lead 75ohm coax.
W8JI
Dave C
Call Sign: 27PL259
Post by Dave C »
ch25 wrote: 22 May 2020, 10:06 I can't see photos, but aren't they wirewound?
Not sure I've posted the pictures properly, can you see these now Chris?
WH50 150R 5% is what they are also patch id 50 Ohm..
Dave
Post by ch25 »
404 now.
Attach photos to your first post.
Dave C
Call Sign: 27PL259
Post by Dave C »
Picture now on post 1...
Post by ch25 »
Wrong type of resistors. That's a reason.
You need carbon type, not wirewound (inductive).
Like: http://qso365.co.uk/2011/08/building-a-dummy-load/
Or: https://www.ebay.com/itm/A3RMK6-RFP-Dum ... 3654436218
Dave C
Call Sign: 27PL259
Post by Dave C »
Took the inspiration from he used inductive resistors, are they NOT wire wounds?
Post by ch25 »
YT is full of shiĦy advices. You just found one :)
Buy that resistor https://www.ebay.co.uk/itm/100w-50ohm-D ... SwX9Bc-hYF or https://www.ebay.co.uk/itm/RF-terminati ... Sw0~pcEz~V or similar.
wa10
Post by wa10 »
The video is using dale none inductive resistors, they have two windings in opposite directions to cancel inductance, it sorta works at low frequencies,
your welwyns are single winding inductive resistors, neither type are suitable for rf dummyload at higher frequencies,
you may be able to cancell most of it out with a parallel capacitor but that aint a rf dummyload anymore, its a very lossy tuned circuit,
good loads have flat vswr over a very wide bandwidth, anything else can screw with your rf power measurements if the transmitter/amplifier is not as clean as a whistle on harmonics,
easy option that will work good enough is one of the flat pack DC-daylight resistors ch25 posted link to & stick it in an old cb amplifier heatsink,
don't use skinny wires, use flat wide strap or braid or copper clad board for wiring.
W8JI
Dave C
Call Sign: 27PL259
Post by Dave C »
Cheers gentlemen for your input, I'll get onto making some alterations....
Best Regards
Dave
