I have a motorola gp640 i bought online. I have flashed the wrong codeplug and like a fool i didnt backup the original properly.
does anyone have a codeplug or any software that might help?
GP640 UHF
tanapa: PMUE1436D
ESN: 041/04/126537
VERSION NO: R02.09.01
kinda hoping ive not turned it into a paper weight
You might need to re-flash the firmware and start from scratch. The flashing software is around, as is the firmware. I'm not familiar with the 640, but I had a similar problem with a 340 and ended up reflashing the firmware on it.
Did you program the wrong firmware or just program the wrong codeplug?
The MPT series of radios (GP640, GP680, GP688, GM660, GM1280) can all take each others codeplugs without any problems, you can load a non display GP640 codeplug into a GM1280 mobile, the cps warns about mismatching products but I've done it many times without issue, other than having to check settings are ok like mobile power, button options etc.
If you've flashed the wrong firmware then that's a different matter and often bricks the thing. R02.09.02 is the most recent firmware but there are so little differences in the last 10 years it's hardly worth the potential risk of trashing a radio by firmware upgrading it.
For default codeplugs there are a load in the default program folder where the CPS is installed (C:\programs\motorola\MPT CPS (or whatever it's saved as) - I can send a default GP640 codeplug if you need one.
I would avoid flashing the firmware unless it was really necessary. You can find the programming software online from various radio hobby sites, but if the first one you download don't work then try downloading from other sites some work some don't.
Does your radio make any beeps when you switch it on and if so how many beeps does it make? I know on some you have to press some buttons on the side of the radio to get it in programing mode then once its programmed switch it off then back on while holding down the side button.
Sorry for the delay guys. I have not tried flashing the firmware. what i did do is make alterations in the cps and made a hash of it, ive then tried to fix it using a codeplug from one of my working gp640's thinking they were the same. when I switch it on, all I get is a constant tone.
Constant tone? - you sure you haven't got the top dial set to a position with nothing programmed into it? (just a thought)
You can program any GP640, 680, 688 and GM660, GM1280 codeplug into another other radio type, the CPS warns of a model mismatch but it works and never trashes the radio (well unless you've incredibly unlucky)
Why not read the codeplug back, check it and write it back it.
Only other thought is: it definetly IS a GP640 and not a GP340 with the wrong sticker on it? while it shouldn't be possible, I've actually programmed a GP340 using the MPT GP640 CPS and codeplug and it trashed the radio (I think I ignored the warning it gave, thinking it was just a codeplug version mismatch!). -some idiot had repaired the radio and used the wrong case sticker! so compare the model number on the label.
I know this is an old thread but I might need some help with some Motorola GP640 radios I have plus a GP340. I know I had the programming software on an old laptop but I can't remember what it was named under... I had lots of radio software I recovered from it.
What I loved about the Motorola GP640 was that you can turn the modulation right up in the programming software and it sounded really nice on air, I always got complemented for my audio when I used that radio on the 70cm Ham band.
Well its been a while and some of the repeater channels are dead and I would really like to change some of the channels, I bought a second GP640 for 18 quid including postage good battery on 449 UK GEN & seems to work and is in very nice condition... I couldn't not buy it. I want to re-program that too, I also won a GP340 in auction for less than 20 quid in unknown condition, it looked good so I took a risk on it. I don't have it yet but if it works I want to re-program that as well.
I don't think I have the programming software for the GP340 but I definitely have the GP640 programming software if only I could remember what name it was under.
Its been a long time since I dabbled with these old radios so I forget things. I'm going to get mine out at some point and reprogram them, one is on 70cms a combination of repeaters and simplex, the other is on UK simple license. I don't think the batteries will be much good as they have been sitting for a very long time unused, I did use the one on 70cms quite a lot back in 2014 to about 2016. I've downloaded the CPS software and I got the programming cable I may need to buy a new charger, I can't remember what I did with the other one I had, I have so much radio junk in various boxes I'll be there for weeks trying to find it.
