Next week I take delivery of a Sirio 827 for my home set up. I guess it needs SWR'ing. I have ordered a meter which comes with it.
Rather than put it up on the side of the house and go up and down SWR'ing can I strap the 827 to its pole and then strap it to the washing pole, SWR it and then put it on the house. What I mean is will the readings change, is it OK to do it this way as it will say=ve me lots of tips up the ladders.
Also what channels do I go to to SWR on a expanded SS 3900 as my Channel 33 is channel 19 and so on...
SWR'ing
Queball
Re: SWR'ing
Have looked at the booklet on the 827 and the top section has to be exactly 420mm from tip to SWR alan key setting,but good luck with it,as it is an awesome aerial.
gholdq on youtube.com
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
phoebe
Queball
Re: SWR'ing
No Phoebe it is quite easy. A monster of an aerial though, what are you going to mount it on as i would think 2 inch pole is ideal although 1 1/2 might be ok as long as there is not too much wind where you live.
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
phoebe
Re: SWR'ing
We do have a lot of wind so I have ordered a 2" pole from a local engineer. I hope this will be OK???
I am also mounting on the side of the pole a Sirio discone scanner antenna for my new scanner. This too will take the wind.
I have been very much advised not to use RG58 cable as its crap. Can you recommend a decent cable for both cb and scanner??
Thanks for all the help
mr_m3
Re: SWR'ing
rg-213 without going to extreme and costing to much it is one of the best cabls for the money
26TM069
M3UBO-----> 2E0FML---->2E0PUC
Queball
Re: SWR'ing
I agree,i am using RG-213 and cant fault it. It is high spec coax and is more expensive. I ordered 10 metres of it from a U.K supplier (Moonraker) and it came with weather proof seals over the pl plugs.If you are planning to mount on a pole with T+K brackets may be worth buying 2 poles instead of 1 as with the weight of the aerial and the pole on the brackets may be too extreme on the brickwork. I live in a detached property and have the brackets on the brickwork underneath the soffit board/gutter.I have cut one of the poles in half, 10 foot each and have jointed one of them to the other 20 foot pole. The 20 foot pole is in the air and is jointed to the 10 foot one UNDERNEATH the brackets.In theory all the weight is then transferred to the bottom 10 foot pole that is then of course on the ground. Luckily i have a single concrete flags as a pathway in the garden so the pole just stands on the flag and takes the weight.Just a tip for you,hope it helps.
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
Re: SWR'ing
The 827s mounts are designed to fit on 1.5" pole. If you want to use 2" you won't be able to use the original mounting system.Queball wrote: i would think 2 inch pole is ideal although 1 1/2 might be ok
phoebe
