Wks1001 mic wiring
jkb
Wks1001 mic wiring
Can anyone confirm is same as the cobra 148 on the uniden chassis please?
Or has the diagram
Thanks john
Or has the diagram
Thanks john
- superstar
Re: Wks1001 mic wiring
Yes it is
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- dt307
- Call Sign: 163dt307
sure mine is cybernet will check
yep my wks1001 is cybernet wiring
guess mine been changed
163dt307-chris
― Albert Einstein
― Albert Einstein
jkb
- 163TM847
- Buick Mackane
- Moderator
- Has thanked: 3 times
- Been thanked: 6 times
obviously a dyed in the wool uniden man lol
I know nothing about CB radios. I only joined transmission1 to get advice on rebuilding the torque converter in my hillman imp
jkb
No I don't have a mic and ordered one wired for uniden!!
I am sending you that Lincoln by the way nick! Had a mare recently.
- 14CS06
- 163TM847
Ah right, From here it looked like being wired Cybernet was a bad thingjkb wrote:No I don't have a mic and ordered one wired for uniden!!
The WKS is definitely Uniden wired, There are only three wires on the back of the mic socket so they can easily be rearranged, The black is ground and sometimes will go across two pins but it only needs to be connected to one.
jkb
