UBC 355CLT thoughts?
				scanningleicester
Hi everyone
I was thinking of getting one of these and attempting to fit it with a disc tap for digital transmissions. However I've put that on hold as I have read about using a dongle instead for that. But now I look into it more I still wonder whether I should get this for my car or even at home. I already have a UBC360 for home use and a 92XLT for mobile walking about. My last main scanner I use is a UBC125XLT for other uses. Any ideas on whether it would be worth purchasing one or not?
Thanks everyone in advance
- Admiral
- Call Sign: 26TM157
- Been thanked: 3 times
Re: UBC 355CLT thoughts?
I have one that's sole purpose is mobile use, they're a very small set, user friendly for mobile (once you get used to it), CloseCall, and as cheap as chips, mine was about £70 brand new over 12 months ago.
Bang-for-buck they're a great little set.
						- Excalibur
I did a written review of this radio a few months back.Overall very pleased with the set
http://www.transmission1.eu/viewtopic.php?f=5&t=46632
				scanningleicester
I've seen one on Amazon for £75 think I will end up getting one.Admiral wrote:I have one that's sole purpose is mobile use, they're a very small set, user friendly for mobile (once you get used to it), CloseCall, and as cheap as chips, mine was about £70 brand new over 12 months ago.
Very informative review, I enjoyed readingExcalibur wrote:I did a written review of this radio a few months back.Overall very pleased with the set
- radiosification
I find that it works much better to use a dongle, personally. I used to use a uniden scanner that I put a discriminator tap on myself, but then when I got the SDR dongle to work, it's just so much easier to find signals with that.
Have a look on my youtube channel, I have videos about how to set it up, if you're interested.
https://youtu.be/5ZWn1sLps2A
https://youtu.be/PjTRx8_KGiI
If you just want it for the discriminator tap, I would say don't bother and just use an RTL SDR instead.
				scanningleicester
Thanks, I ended up getting the RTL Friday and stumbled across your videos actually which helped me a lot with SDR sharp. Slight problem with the voice being unreadable when its decoded but im hoping to test that with my digital radio (Hytera PD365) from work later tomorrow.
						- radiosification
Glad they helped. Try messing with the filter settings and double check that filter audio is not ticked. I usually use 8000Hz for DMR. Also try listening in analog too, maybe the signal strength is just too bad.scanningleicester wrote:Thanks, I ended up getting the RTL Friday and stumbled across your videos actually which helped me a lot with SDR sharp. Slight problem with the voice being unreadable when its decoded but im hoping to test that with my digital radio (Hytera PD365) from work later tomorrow.
- Admiral
A dongle isn't much use mobile, the 355 has a lot of stated uses, but it's a good mobile set.
				Windy_Miller
For a car, the options are more likely to be down to an all in one unit that can deal with digital without a laptop hanging off it.
AOR DV-1 looks like the kind of thing that could be promising, but at a significant cost.
Uniden BCD536HP would be a more realistically priced alternative, although its firmware doesn't as yet support UK digital modes, and there is no word that they ever will - Although in theory, a bit of firmware should do the job.
The 536 would be a very competent analogue mobile scanner however. 355 looks very "vintage" by comparison.
- Admiral
Radiozing are knocking them out at £65 with free postage at the moment.
http://www.ebay.co.uk/itm/UNIDEN-BEARCA ... 1ea12e7e54
